bcheney's Avatar
SC alternator wiring
I have a 914/6 conversion with a 2.2 with carbs. I had to take my alternator out to have it replaced and have lost my reference wiring pics from when I took it apart. The alt I am using is from a 911 SC...the pics below show you what I have...Wiring is not my strenght...can someone chime in and let me know where each of the wires go? I believe h B+ is where the power (red wires) attach...its the wire in my pic that has a boot on it. I am not sure where the little blue wire attaches and where the ground wire goes.
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 03-09-2015, 11:34 AM
bcheney's Avatar
SC Alternator wiring
would this be correct....Red is power...Blue is for the volt meter...brown is for ground from crankcase....
08 Cayenne V6
75 914-6 Conversion
Old 03-09-2015, 01:23 PM
Blue goes up top ground is across from the positive
Old 03-09-2015, 01:28 PM
If it a Bosch alternator blue goes up top, you have the positive correct and the brown(ground) goes across from the positive
Old 03-09-2015, 01:32 PM
bcheney's Avatar
alternator
Ok so are you saying I cannot attach the ground to the stud I have circled in brown in my picture? I have buttoned everything up like that and I got the engine started and running...now the system is not charging...put a meter on the battery and it reads 11.84...the volt gauge is just a shade below12 and the red battery charging light is illuminated in my dash gauge between the temp and pressure readings... it stays illuminated even when I bump up the revs above 3000rpm.
08 Cayenne V6
75 914-6 Conversion
Old 03-14-2015, 08:42 AM
bcheney's Avatar
Alternator woes
Lookin for some help ya'll...
08 Cayenne V6
75 914-6 Conversion
Old 03-14-2015, 09:17 PM
Jonny H's Avatar
You got all the help you needed in post #3!
Old 03-15-2015, 12:01 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Alternator is a 90amp unit.
Red to B+
Brown to D-
Blue to +61
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 03-15-2015, 04:46 AM
wachuko's Avatar
Drive safe!
1967 - Porsche 912
Old 03-15-2015, 04:53 AM
kodioneill's Avatar
Post 3 is wrong so he didn't get the help he needed.
The blue wire goes to the bottom lug on the right side. ground goes to the top right. red+ goes to top left post.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-15-2015, 06:48 AM
Wrong!!!!!!
You were looking at the picture posted by Wachuco upside down!!!!! Post #3 is correct.
Tony
Old 03-15-2015, 12:01 PM
wachuko's Avatar
Tony
Exactly...reason why I posted where the wires actually go to... Do not let the orientation of the photo confuse you...
Drive safe!
1967 - Porsche 912
Old 03-15-2015, 01:43 PM
Fahren mit dem Wind.
mhackney's Avatar
Since I'm installing a new alt (Bosch) in my 83 SC Cab, I found this post on the process of verifying my wiring. Post #3 is absolutely correct. In fact, you can see the posts have a stamping near them that read B+ and D-. B+ is the red wire (positive) and D- is ground (brown wires) leaving the unlabeled post as 61, the blue wire. Wachuko's alt has the posts label + and -. Hopefully this brings closure and helps others in the future!
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 07-24-2015, 05:31 PM
