RallyJon's Avatar
Question Will a Carrera manifold bolt to an old motor?
Thinking about converting a 2.4 to a homebuilt EFI setup. I assume the ports would need a bit of work, but is the spacing and bolt (stud) pattern the same?
Used Carrera intake manifolds are a heck of a lot cheaper--if a bit less sexy--than TWMs!
Old 11-15-2002, 10:14 AM
same bolt pattern. carrera heads were shorter to compensate for the phenolic spacer. the carrera ports are 41mm. hugely different from yours.
206 637 4071
Old 11-15-2002, 12:19 PM
