2002 996 C4S
jcsjcs's Avatar
Bosch Battery backwards?
Bought a "Bosch Premium Performance Battery Group Size H6/L3/48" as they have a 25% off deal going on for batteries at Pep Boys. Got it home, took out the old, started installing and it's backwards!
Considered just flipping the battery with positive near front of the car, but the wires are not long enough. Wrestled it in - and now the battery posts are closer to the fender rather than the trunk. The battery is in SOLID using the standard mount.
Do I need to be concerned about the positive post being about 1.5" from side of car? There is actually a plastic cover between the post / wire and the wall and it's not going anywhere - but wanted some opinions.
NOTE: I do see they make a right and left battery but I don't think they have it at my Pep Boys.
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 06-25-2016, 12:04 PM
i think your old battery was installed backwards. the picture shows the stock configuration
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 06-25-2016, 12:15 PM
RETIRED
Joe Bob's Avatar
ALWAYS cover the positive terminal.
2012 ML350 3.0 Turbo Diesel
Old 06-25-2016, 12:31 PM
^^^^ What he said. Your new battery has the correct orientation.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 06-25-2016, 12:45 PM
2002 996 C4S
jcsjcs's Avatar
Recommended cover?
Old 06-26-2016, 09:01 AM
The battery should have come with a plastic piece that covers the terminal. There are usually 2 holes on top were it slides in. Go back to Pep Boys, they fall off sometimes and get lost.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-26-2016, 11:47 AM
2002 996 C4S
jcsjcs's Avatar
Good?
Old 06-26-2016, 12:14 PM
Yes.
Old 06-26-2016, 01:29 PM
Just looked at my battery. Car came without a cover for the positive terminal, do you have a suggestion of where/what to buy to put one on? Also, can you educate me on why the positive terminal must be covered?
Who, What, When, Where, Why and How.
Old 06-26-2016, 08:31 PM
El Duderino
tirwin's Avatar
Because if something touches it accidentally it could complete the circuit -- like you. Or something could fall across the terminal posts. Also it's a good idea to take off stuff like a wedding ring when you're messing with the battery. I also have a quick disconnect. I've probably used it a hundred times when working on the car.
Take a look at something like this:
https://www.amazon.com/Allstar-ALL76150-Plastic-Battery-Terminal/dp/B006K8V7KS
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 06-26-2016, 09:08 PM
Also cover the positive battery to keep it from grounding on collapsed body work in the event of an accident. That could cause much merriment next to the fuel system. In addition to the battery terminal cover, I've fashioned a couple piece of heavy rubber (like an old inner tube) to tuck in between the battery positive terminal and the car body.
Old 06-26-2016, 09:34 PM
RETIRED
Joe Bob's Avatar
Go back to where you bought it. Make them fix it.
Old 06-26-2016, 09:54 PM
Road trip!! Only about 700 miles, one way. Good thing I have nothing planned for Tuesday.
Thanks for the replies guys.
Old 06-27-2016, 12:08 PM
