After being parked for 18 months ( i was deployed) drove the 1978 911SC home from my son's garage. All was good, usual smoke from a long parked engine which quickly dissipated, it drove fine until i hit the brakes hard and the pedal stayed down with brakes engaged. I pulled over and discovered the the pedal can simply be pulled back up and brakes disengage.
It continues to do it. Is there a return spring of some sort or is the master cylinder shot, or what? |
Banned
sounds to be the pedal assembly or maybe the rod going up to the master if your able to disengage by pulling the pedal back. i would start there.
First guess, brake pedal assembly at the pedal housing.
Second guess, master cylinder. Third guess, leak in the line.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Banned
I would rule out the leak because of him being able to disengage by hand. A leak would just cause the pedal to hit the floor with no engagement.
Is the pedal supposed to move more than an inch?
Rick 88 Cab |
Banned
They should have like an inch to an inch and a half before you feel the piston.
and then that Incompressible Fluid shouldn't let it move much more. If it is going to the floor that is a problem.
Rick 88 Cab |
Pedal actually moves about two inches then stops before the floor and does not return
It does not go to the floor I just Went back out started the car checked and measured travel with a measuring tape |
return spring in the master cylinder? I s there a lot of travel like the front or rears are empty?
Rick 88 Cab |
Other thanthe failure to spring back everything else feels correct
