Thoughts on my 88 carrera oil leak
Hey guys, I realized my 1988 carrera 3.2 has a small oil leak. I’ll be taking it in for a service job this spring but wanted to see what your thoughts were on the location of the leak, etc. is this an area for major concern? Unfortunately I know very little on repairing cars. I appreciate any opinions .
1988 carrera 3.2 coupe
Old 02-24-2019, 01:29 PM
proporsche's Avatar
do some search, engine top oil leak...oil press,switch thermostat o ring and breather cover gasket..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-24-2019, 01:44 PM
Recreational User
porschenut's Avatar
What you're showing is the location of the oil drip, but not necessarily the leak source. It may be dripping down from above. There are several common leak points on the top of the engine. You'll need to verify where the leak is coming from. Your shop can do that.
Leaks are very common on air cooled motors. 99% of the time they are just a nuisance, not requiring repair. nature of the beast.
Old 02-24-2019, 01:49 PM
What does it smell like?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-24-2019, 02:07 PM
Check out these threads on "triangle of death":
Pelican Parts Forums - Search Results
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 02-24-2019, 02:08 PM
May be a leaking slave cylinder on top of the transmission, whick leaks into the bellhousing and comes out the hole at the bottom. Maybe.
206 637 4071
Old 02-24-2019, 03:18 PM
Could be.... the OP should be able to smell the difference between oil & brake fluid.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 02-24-2019, 03:52 PM
Flojo's Avatar
Seal behind flywheel
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-26-2019, 02:30 AM
proporsche's Avatar
Flojo..... it is is the flywheel seal it would more mess on the cross pipe;-)(the flywheel will spread the oil ).The op has to look on top of the engine and hopefully he will update this..here...
Ivan
Old 02-26-2019, 03:03 AM
Flojo's Avatar
Ivan. Mine was just a further hint ;-)
And: it doesn't show oil mess on the crosspipe, as it burns away under the heat. depends on what moment the pictures were taken (hot or cold).
I do remember very well when my flywheel seal was shot and above the triangle was dry....
Old 02-26-2019, 04:57 AM
proporsche's Avatar
maybe but his cross pipe is totally without any oil marks..so he should really look on top;-)
Of course any idea might help him;-)
Ivan
Old 02-26-2019, 05:31 AM
911timesThree
rolfjahn's Avatar
Ivan
When you say flywheel seal do you mean rear main seal?
1987 911ST 3.4L G50 LS 20/21 Granite Green Hot Rod
1988 911 3.4L G50 LS 20/21 Guards Red Hot Rod
2020 F87 M2 Comp 6Speed Carbahn 562/567
Gone: 1991 965 Black/Black Turbo
Gone: 2002 E46 M3 6Spd CSL style build
Old 02-26-2019, 09:33 AM
proporsche's Avatar
Yes that what is called -- flywheel seal;-)at least what we called in CA in my shop since 1980 ..it could be called crankshaft seal that could be confused with front crankshaft seal..which is front pulley seal....therefore flywheel seal....put it in google it will tell you;-)
Ivan
Old 02-26-2019, 09:43 AM
Northern Motorhead
wildcat077's Avatar
First place to look is the "triangle of death " , that's the area on top between the front of the engine and the firewall ... they all eventually leak from there at some point , and the oil finds it's way down , do a search , there's plenty of info.
Get a couple cans of brake clean and clean up the areas where you see oil , it'll be easier to determine where it originates from.
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 02-26-2019, 09:49 AM
Ivan
Not true. The rear main seal leak will just drip down to that same spot.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-26-2019, 10:44 AM
proporsche's Avatar
ok if you say so .........
Ivan
Old 02-26-2019, 10:56 AM
proporsche's Avatar
Flojo..if you remember your flywheel seal was leaking because you used the lesser kind seal and it leaked, you did not put any km on the engine then you replace it with the correct seal;-)
Ivan
Old 02-26-2019, 11:09 AM
Still here
pmax's Avatar
Take some pics of the area around the breather hose where it connects to the case at the "back" of the engine and see if it's a mess.
The 3.2's are great and can be leak free !
Old 02-26-2019, 12:57 PM
What's km?
Let's hope it's just the triangle of death or clutch slave cylinder... won't need to drop the engine to take care of that.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
proporsche's Avatar
The 3.2's are great and can be leak free ![/QUOTE]
absolutely correct...;-)
Ivan
Old 02-26-2019, 01:15 PM
