Original engine pad for my 1987 911 Targa basically deteriorated to small segments and dried up form. It's fully out now but a decent amount of adhesive/glue remains.
Any suggestions how to best/safely remove without scratching the paint underneath or any engine components? Engine is in the car (not dropped). And am thinking about simply not replacing the pad too................... thanks, Dave |
Spiderman
Same here as Fast Mike when i did mine. Got the "thick pad" via app biz from our host and installed with no glue per App. Has been in for years, it does not move. I only removed the easy hunks and bits left behind before re-install. Don't stress on cleaning it up, the factory glue was not intended to be removable.
A partial engine drop would likely make access for install easier. If you don't replace the pad with something, you'll have to look at a really ugly fire-wall or make a huge effort to clean.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Fast Mike - is yours the AppBiz "Double Reinforced" or "Ultimate" pad (as listed on our hosts site)? thanks
If it's the double foil sided pad, it's AOK. Spend the extra on the Ultimate, it's 3 ply and a bit better at sound isolation. You'll be happy you did!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Spiderman
Thought I remember App Biz saying foil toward engine to reflect the heat. That's how mine is and it looks great. Head scratch whether foil also on the other side, been too long.
I like the foil look.
Don't know if he still offers it, but he used to offer a pad with foil on both sides, but that's not the Ultimate. However yours is installed is your choice and if you're happy with it, that's what counts. Other than opting for original appearance, I'm sure it makes little difference how it is installed. When I installed mine, I was confused so I called AppBiz and he gave me the above info.
Dial 911
how to
I also left the old glue but also used 3M's spray adhesive that they recommend for hood insulation on 'normal?' front engine vehicles. When it sticks that's it so make a trial run and make sure that your top edge is correct if you start sticking it at the bottom first.
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
