North Coast Cab's Avatar
Question New Rotors
Can I put a new set of cross drilled rotors on the front and leave the OEM solid on the rear? The rear are very new and in great shape but the fronts ned replacement. In the middle of replacing brake hoses, rebuilding calipers and changing fluid.
JG
1985.5 944 GTS
Old 11-15-2002, 05:44 PM
Navin Johnson
TimT's Avatar
Yes
'69 911 GT-5
'75 914 GT-3
and others
Old 11-15-2002, 06:15 PM
I'm sure you've heard this before, but just in case. The drilled rotors wear out faster than the non drilled. I don't know that they necessarily wear past the useable limit, but they end up cracking. The best benefit is some improved cooling and reduced unsprung weight, but then you will also face having to replace them slightly more often. Of course, it sounds like you've already got them in which case you will likely care very little anyway.
But to reiterate the answer to your question is, "Of course!"
Old 11-15-2002, 06:31 PM
