Another wheel / tire / offset / backspacing question
Hi Guys -
I just sold my previous wheels and just purchased a set of the 52 Outlaw (Magnus Walker) wheels. My previous fronts would rub under hard cornering by where say the dead pedal would be (if that makes sense?). Here are the stats of the wheels I had:
Front:
  • 17x9 with 5-5/16 backspacing
  • 245/45 r17 tires
  • Backspacing to offset conversion is et8
Rear:
  • 17x11 with 5-1/2 backspacing
  • 275/40 r17 tires
  • Backspacing to offset conversion is et-13
  • 22mm spacer
The new wheels are 17x9 et11 front and 17x11 et-8 rear. Because the front is inset 3mm I'm wondering if my rubbing will be worse and am considering going with a 235/45 tire instead. I was really hoping for the 245's for some added contact surface however these tires are almost 3/4 inch taller than original which could be causing the problem in the first place.
What are your thoughts? 245's with a 5 mm spacer up front? or 235's with no spacer?
Also a recommendation on a good street tire would be appreciated!
1980 911 SC - Black on Red
Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html
Old 07-31-2015, 07:36 AM
I think 235 section width tires are plenty on the front of a 911. Yes, the diameter will make a big difference in rubbing. I like the Bridgestone RE11.
JR
Old 07-31-2015, 07:45 AM
Fastest Hunk of Junk
This is a widebody, FWIW.
Why not 245/40/17, a much more common size and 24.7" OD?
Did you mean 17x9 up front, I assume? I doubt anyone is fitting 11Js up front...
-Brent
Old 07-31-2015, 08:36 AM
Brent - I'd have to do a 245/40 up front with a 275/40 in the rear. Doesn't match OD wise. I dont see a front / rear tire combination that matches the 24.7 OD.
Old 07-31-2015, 08:44 AM
I ran 235/255 on one of my turbos. Worked fine, but my rear wheels were 10x17.
Sometimes stuffing the widest tire you can fit under a fender just slows the car down. My .02...
JR
Old 07-31-2015, 08:56 AM
True- I don't worry about that much on a 2WD vehicle and have personally run differing OD tires before on other cars, but I understand if you don't want to/the tire shop won't allow it.
I agree that a 235/45 is enough tire up front if you want to be safe, though 235-275 is quite a stagger IMHO. You didn't mention the brand, either--obviously something like a Michelin usually runs "true" width, while say a Dunlop Z2 with very square sidewalls runs wide.
-Brent
Old 07-31-2015, 08:58 AM
I was given a virtual crazy look when i told them what I had on the car (11" wheels with 5.5" backspacing and a 22mm spacer). I basically asked for a 17x11 wheel with et-33 for the rears. SC suspension with turbo flares.
Am I nuts or does this sound right?
Doing the math:
- 11" wide wheel means 12" from outer rim to outer rim
- et-33 oiffset translates into 1.3" off the centerline of the wheel
- so effectively that's (12"/2)-1.3" is the backspacing. So let's say 4.7".
- front of hub to the fender lip would then be (12"-4.7") OR (12"/2)+1.3" = 7.3 inches
If I go this aggressive with the offset I will assume that an upgrade to a 315 tire in the future will probably not work as with the 275's it was tight with the fender. Keep in mind it's only an SC and the biggest power upgrade I would ever do is a stock 3.6 which I don't think would need a 315 tire.
Old 07-31-2015, 12:31 PM
Just updating this for later users. I decided on the following and have been running this setup for 3 months without a problem.
Front
- 17x9 et8
- 245/40 17 tires
- no spacers
- I have more room in front for a wider tire with this setup
Rear
- 17x11 et -19
- 275/40 17 tires
- 12mm spacers
- pretty tight against the outer lip but no rubbing.
Old 12-30-2015, 05:05 AM
Cars Ruined My Life
impactbumper's Avatar
Pics?
Old 12-30-2015, 06:38 AM
non-whiner
mreid's Avatar
Scott, I run 245/45-17 on the front and 315/35-17 on the rear with no spacers. I roller the front fenders as I has a slight rub at full lock. My car is a middy with turbo flares.
"Too much is just enough."
Old 12-30-2015, 06:50 AM
Berk - not the best pictures but it's all I got for now.
mreid - Do you know what offset your wheels are?
Untitled by sicklyscott, on Flickr
Old 12-31-2015, 06:44 AM
Send a message via Skype™ to kyngfish
Nice Setup
A few questions:
- why these instead of the new Fuchs?
- how much do these wheels weigh? I don't see anything on their website.
Cheers,
Martin
Old 12-31-2015, 07:04 AM
Originally Posted by kyngfish View Post
A few questions:
Cheers,
Martin
I wanted something different while nodding my head to the classic design.
I didn't weigh these before i mounted them. They were fairly light for their size but i don't have actuals.
Old 12-31-2015, 07:28 AM
Alright, fair enough. I am thinking of getting wider wheels for my non-flared 86 and I want to keep them looking original while making them as light as possible. Fuchs actually makes new wheels which aren't too dissimilar from these. I was just curious if there was a reason to pick one over the other.
Also, about your ducktail, is that something that fits over the current decklid, or is it an entirely new decklid with ducktail?
Old 12-31-2015, 07:31 AM
If you want to have light wheels, stick to 16" Fuchs.
I'd look at how wheels are made, to pick one over the other. Forged wheels would be preferable to cast wheels. The Fuchs company probably knows more about forging than any other wheel company.
JR
Old 12-31-2015, 07:48 AM
Entirely new ducktail.
I second what Javadog said. I'd probably talk to Jeff Alton or Zuffenhaus (1 in the same?) about your desires and see what they have to say. I've dealt with Jeff before, always good to work with and very knowledgeable.
In the end I may end up with a set of Braid Fuch wheels for track duty but that'll be down the line once I address some other items.
Old 12-31-2015, 09:10 AM
Mick_D's Avatar
Wow, that's the best-looking application of those outlaw rims I've seen. I'm not normally a fan but on that car in that finish and fitment wow!
Old 12-31-2015, 11:40 AM
