Low cost electrical improvements - neg battery cable, ground strap, clean door switch
I thought I would pass on some electrical tips that made a difference on my 85. I needed a new battery as it was testing about half its rated cranking amps. Because the previous owner had a parasitic draw he never fixed, he put in a gigantic 1100 CCA battery. At half capacity it still started the car - and I drove it like this for 2 years.
I got rid of that boat anchor and got a AGM sealed H6 battery per the many great recommendations on this board. But to take it a step further, I ordered a new negative battery cable and a new transmission to body ground strap from our host.
The new ground straps are inexpensive and fairly easy to install.
The car seems to idle better and the gauges seem a bit smoother. I think 30 year old ground straps cannot be as good as new ones.
I then tested the parasitic draw and traced it to the door switches. 10 minutes of pulling them out, sanding them shiny again and adding a dab of contact grease and my parasitic loss is nearly gone completely.
If you have a regular battery drain and/or any strange electrical issues, I'd try these easy fixes in your troubleshooting.
1985 Coupe, Rennshift, SW chip, 7/9s, LSD
Old 08-02-2015, 04:44 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Good Job!
'85 Carrera Targa
PCA/POC
Old 08-02-2015, 04:56 PM
Good work and good advice!!!
thanks.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 08-02-2015, 05:12 PM
Nice job Jeff!
S
Old 08-02-2015, 06:16 PM
Functionista
manbridge 74's Avatar
Long ago I heard from an old timer, "clean, bright and tight." Can keep a myriad of problems from developing.
Nice work and a question. Did the new cable and strap look like the old ones in every way? Like soldered instead of crimped ends?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 08-02-2015, 06:21 PM
the new negative battery cable from Pelican looked much better - it was fully insulated and soldered vs. the old corroded, bare wire crusty one. The new transmission copper ground strap was nice and shiny with soldered filled ends. I had to grind one end a little to round it so it would fit flat on the stud but no big deal.
Old 08-02-2015, 06:56 PM
I just replaced my battery negative strap with the same cable you show above. It looks much better than the old one, and I think my starter cranks faster now. Might be my imagination, but I don't think so.
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 08-02-2015, 07:16 PM
