-   -   What is this part for ?? Help (http://forums.pelicanparts.com/porsche-911-technical-forum/877606-what-part-help.html)
Beakster 08-04-2015 01:06 PM
I need help finding out what this Big rubber gasket is for .. Thanks http://forums.pelicanparts.com/uploa...1438718736.jpg
DRACO A5OG 08-04-2015 01:48 PM
we need a reference point, put a ruler next to it
Cairo94507 08-04-2015 02:04 PM
OK, I am guessing trunk seal, door seal.....
Trackrash 08-04-2015 02:09 PM
Looks like a door seal, but hard to tell from the picture.
ganun 08-04-2015 02:10 PM
Door, trunk has two wings on it the width of the front of the trunk.Door has one 90 degree bend on it.
irl 08-04-2015 03:27 PM
Lay it flat and try to get it to show the shape by taking the twists out of it. Too hard to tell when it's all squirrels like that
Beakster 08-04-2015 04:09 PM
It's 4ft at the top and 5ft at bottom sides are about 2ft .. I was thinking maybe the gasket that goes around a targa back window ..
93nav 08-04-2015 09:04 PM
If it has one 90 degree (+/-) corner, and the two 'sides' of it are different, one firm, the other squishy (hollow) I would vote for door seal. Assuming you have access to a car, stick the 90 degree corner in the top back side of a door opening and then follow the seal around the rest of the door opening. May seem a little short, but that may be normal.
Bob Kontak 08-04-2015 10:00 PM
How "heavy" is it? Door/front trunk seals are relatively wimpy.
I think you may have it nailed but I cant be sure given pic does not show left "hard" corner.
