lespaul's Avatar
50 rpm idle hunt on 78SC 3.0L
I just put new intake boots on my 78 SC to correct an air leak. Set the mixture without an analyzer using techniques on this site. Might be slightly rich but runs nice and cool and even through all RPMs under a heavy pedal. Good power and acceleration with no hesitation, hiccups, grumbling or back firing. Idle set at 950-975. However, after warm up, I get a 50 rpm idle hunt.
What might cause that?
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 08-04-2015, 08:37 AM
Member 911 Anonymous
DRACO A5OG's Avatar
As you wrote, it may be a but rich, try leaning her out a tad see if that will clear up the minor hunt???
'85 Carrera Targa
PCA/POC
Old 08-04-2015, 10:12 AM
Reiver
Reiver's Avatar
Rich mixture can do that...lean it a tad until it stops hunting but the idle does not increase in rpm.
De Oppresso Liber
Strength and Honor 5th Legion
Old 08-04-2015, 10:15 AM
lespaul's Avatar
Thanks. I did try that but it started to hesitate at 4-5000 rpm with a heavy pedal, so I went back to a tad richer and the hesitation went away. It doesn't bother me since I don't sit at idle much but it is not correct. The car was not designed to hunt like that.
Brad
RETIRED
Joe Bob's Avatar
Still sounds like a leak. You need an analyzer AFTER hunting down leaks. Propane or ether spray....listen for rpm changes.
2012 ML350 3.0 Turbo Diesel
Old 08-04-2015, 10:16 AM
lespaul's Avatar
I will try just a tiny leaning and see what happens.
Brad
Eva
911SauCy's Avatar
thats your best bet
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 08-04-2015, 10:36 AM
Seeking
Years ago, I was taught to enrichen until the engine starts to seek an idle, then lean it back until you're smooth, then adjust the air on the TB for idle speed.
Bruce
Old 08-04-2015, 02:47 PM
Reiver
Reiver's Avatar
A water mister spray works fine too...drops the rpm when there is a leak and you can't blow anything up.
De Oppresso Liber
Old 08-04-2015, 03:01 PM
c2kid's Avatar
hmm
I would think vacuum leak as well. on the wide side maybe breather leak. cheers, Geoff
Old 08-04-2015, 03:08 PM
lespaul's Avatar
Leaned it a hair and now have a 25 rpm hunt. Gonna lean it one more hair. Will report back.
Brad
Old 08-05-2015, 05:13 AM
lespaul's Avatar
Down to an intermittent 10 rpm hunt once in a while. Gonna lean her one more smidge. I don't think I have any significant air leaks -- plenty of room to adjust idle as needed.
Brad
Old 08-06-2015, 12:00 PM
Eva
911SauCy's Avatar
10rpm hunt...on a 37 year old CIS car. You're dialed in just right.
Old 08-06-2015, 12:22 PM
83 SC
tkmoore's Avatar
Subscribe
Old 08-06-2015, 01:14 PM
lespaul's Avatar
I did not do the final lean. Instead, I put some fresh gas and a dollup of Marval Mystery Oil in and ran it up to red line a few times. No hunt at all now, rock steady at 950 rpm. I am putting a fork in it and calling it done. Thanks for all the advice.
Brad
Brad
Old 08-07-2015, 07:10 AM
lespaul's Avatar
Here she is with a fresh Brazilian Wax Job.
Brad
Old 08-07-2015, 07:30 AM
DRACO A5OG's Avatar
NICE!
A bit OCD, eh? Well, I think we all are :-) for our babies.
Yeap an Eyetalion Tune Up once in while is a good thing :-)
Congrats Brother,
Jim
'85 Carrera Targa
PCA/POC
Old 08-07-2015, 07:54 AM
