Spring Plate Color/Finish
Were the spring plates painted, or just left yellow cad plated from the factory in '76?
Old 10-13-2014, 04:31 PM
Cad plated
Old 10-13-2014, 06:30 PM
Thanks much ... I thought that was the case, but I see so many of them painted I was not sure.
Old 10-13-2014, 10:59 PM
I am just about to plate my spring plates.
Is it cad plated, or zinc plated?
Bob
Old 10-14-2014, 09:30 AM
WAS cad plated originally, but because of environmental issues (heavy metals) it is harder to find cad platers now. Yellow zinc works great, though, and looks good.
Here are my recently yellow zinc plated spring plates...
Old 10-14-2014, 09:38 AM
Carmagic.us
rothaus's Avatar
Who did the plating for you ? They look great. I need to plate also the spring plates, and some other parts, for my 70 911T
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 08-07-2015, 05:49 AM
I use EPI, in Clinton Twp., Michigan. They are very reasonable. I also had them do all of the small parts on my engine (brackets, etc.) when I rebuilt it this past winter. Great work. I am sure you can ship your stuff to them. Just give them a call. +1 866 554-3431. Electroplating Industries, Inc.
As they will tell you, just be sure parts are relatively clean when you send them. Even though they will do an acid dip, it's better if you have them clean to begin with.
Good luck.
Lyle.
Old 08-07-2015, 02:05 PM
Gold zinc, and make sure all bolts, threads etc are cleaned on a wire wheel, for the larger parts such as spring plates sandblasting for preparation is the go.
Old 08-07-2015, 04:24 PM
Under the radar
Trackrash's Avatar
How do you keep this plating looking fresh? Mine always dull after a year or two.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-07-2015, 05:05 PM
At least through 73 the spring plates and torsion bar housings were black. You can powder coat for durability.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-07-2015, 05:24 PM
Dial 911
A horse with no name's Avatar
How to keep them'shiny'.
I have given parts/pieces that have been anodized or zinc coated a couple of coats of clear-coat and it has stayed on very well. If they say get stone chipped, clear coat is easy to sand so as to clear-coat them again if required. I have never had to do so.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 08-07-2015, 10:51 PM
