transmission fluid change
Ok, this should not be that hard but it s my first time. I am changing the transmission fluid on my 84. Removing the drain plug is not a problem, once I switched from my ratchet to a longer torque wrench. Getting to the fill plug is a different option. Porsche engineers should have moved it aft about two inches. Is there a trick to getting my hex socket properly seated? A lot of junk is in the way. I now assume i have to decouple whatever that is the is sliding pack and forth right in front of the plug (throttle?)?
Any advice is appreciated. Thanks. Last edited by Hoppe; 08-02-2015 at 06:49 PM.. |
Member 911 Anonymous
I used my shorter inch/ft torque wrench ( same size as my standard 3/8 ratchet ) use some anti-seize
I think you can rent one for free at your FLAPS.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 08-02-2015 at 07:15 PM.. |
Cars and Cappuccino
Reversible topside oil changer is ideal. Otherwise it is a total PIA.
Burnin' Rubber
Had to use a lift in the end to get enough leverage on the filler plug. There's enough room if the car is up high with a flexible joint extension
Let's hope you can remove that fill plug. Next time, always remove the fill plug first to make sure you can. If the fluid drains out and the fill plug can't be removed, you've got a problem.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
not my pics but I use this on my gt3 which has access issues due to the cooler. I used on my 89 and worked great
Basically put bit in the fill plug, attach torque extender, attach thin head ratchet or breaker to the extended. You can get a lot of leverage and allows for the odd access angles. The extender I have is made by Armstrong. ![]()
I just did this yesterday on my car. It's an old hotrod so not a lot of stuff around the filler plug but I did have the throttle linkage & clutch cable in the way. I was able to use a 1/2" drive 17mm hex driver but it was tight and hard to get off the plug after breaking the plug loose enough to remove. However I did notice that once the hex head driver is in the plug there appeared to be enough of the hex drive visible to slip a combination wrench onto it right against the filler plug. So perhaps you can try that?
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Fahren mit dem Wind.
Do you have one of these? It is short enough to get into the small space for the plug on my 83 SC fill plug with a 3/8" socket or breaker bar. Makes it easy to remove the first time and dead easy in the future with regular fluid changes.
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net) Caregiver to: 1983 911 SC Cabriolet - Fahern mit dem Wind. (Moss Green Metallic over Champagne and Brown Leather) |
I have the hex socket. I used it with an adapter with my ratchet. With the adapter, you could not get in there well with the throttle linkage in the way. I then got a breaker bar that sits lower but the linkage is still preventing movement. I guess I just need to uncouple the linkage and raise the car up a little more so I can get a better position on it. The tools Spyerx posted might actually work best.
Ive been there / done that myself. ..doing something smart for once
Get this tool, as sold by our host. Just changed my fluid again with it last weekend without even a second thought:
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=005773-0-M84&catalog_description=&Transmission%2520Drain%2520Plug%2520Tool%2520%2520 %2520%253Cfont%2520style%253D%2522font%252Dweight% 253Anormal%2522%253E%2520%2528%2531%2537%2520mm%25 20hex%2520%252F%2520%2533%252F%2538%2520inch%2520D rive%2529%2520%2520
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
the issue with the plug is leverage. its crowded near the fill plug but you can stuff a hex bit and an adapter in there. 3/4 breaker bar, plenty of muscle for this job. think about it, you always want to have more leverage than you need, its way safer and gets the job done.
i got one at HF. its also a must for the rear axle bolt
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
New drain/fill plugs go a long way to safety here as well.
The newbie finally got his transmission fluid changed. A hinged breaker bar and jacking the car a little higher were the keys, along with decoupling the throttle linkage (if that is what that was that was in the way). The biggest pain was using the transfer pump. The hose was way to short.
Fleabit peanut monkey
Good job.
1981 911SC Targa |
