-   -   "chain ramp pin" question (http://forums.pelicanparts.com/porsche-911-technical-forum/878192-chain-ramp-pin-question.html)
T77911S 08-09-2015 12:11 PM
This is the backside of the pin. Looks like epoxy is chipped off. Will the pin come off if all the epoxy comes off.
Epoxy or JB weld.
http://forums.pelicanparts.com/uploa...1439147508.jpg
Steve@Rennsport 08-09-2015 01:31 PM
I would clean out all the old sealing material, prep the area, and apply JB weld.
T77911S 08-09-2015 03:55 PM
Thanks. Does that hold the pin. I just saw a post where someone found a pin in their oil pan
boyt911sc 08-09-2015 04:09 PM
Chain ramp pins........
Ty,
Do as what Steve suggested. That's what I did to the engines I have in the garage. Clean well and apply sufficient amount of JB Weld. The pins should be very tight on the chain housing. If you could feel slight movement from its mounting, that would be a problem.
Tony
Gordo2 08-09-2015 06:48 PM
Chain Ramp Pins
The pin is press fit into the case - the JB weld or other epoxy seals it so it doesn't leak oil.
Gordo
