T77911S's Avatar
"chain ramp pin" question
This is the backside of the pin. Looks like epoxy is chipped off. Will the pin come off if all the epoxy comes off.
Epoxy or JB weld.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-09-2015, 12:11 PM
I would clean out all the old sealing material, prep the area, and apply JB weld.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-09-2015, 01:31 PM
T77911S's Avatar
Thanks. Does that hold the pin. I just saw a post where someone found a pin in their oil pan
RACE CAR:: sold
Old 08-09-2015, 03:55 PM
Chain ramp pins........
Ty,
Do as what Steve suggested. That's what I did to the engines I have in the garage. Clean well and apply sufficient amount of JB Weld. The pins should be very tight on the chain housing. If you could feel slight movement from its mounting, that would be a problem.
Tony
Old 08-09-2015, 04:09 PM
Gordo2's Avatar
Chain Ramp Pins
The pin is press fit into the case - the JB weld or other epoxy seals it so it doesn't leak oil.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 08-09-2015, 06:48 PM
