Elombard's Avatar
No way dude! if you get it wrong try again!! when you finally get it the feeling of satisfaction will be immense!! When I finished my first 911 engine tranny R&R I figured if I ever got layed off I could just go get a job as a Porsche mechanic!! : - ))
Take a couple of days off, organize and clean your tools, straighten up the garage and cut NO corners this time through. I remember the first time I did a cam in a 70s Z car, I had no idea that it mattered what orientation the cam went in!!! ( thank god for non interference motors..)
I bet our wife (and family) is sick about the angst this is causing you. Get a grip relax and enjoy the challenge. You have done the hard part!!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 11-19-2002, 06:51 PM
crashr's Avatar
Is it even possible to damage the valves if you turn the engine by hand? I am about to start rebuilding my engine in December (waiting for Waynes book to come out) and from 101 projects and a tech article on pelican parts I thought that cam timing was not suppose to be a difficult task. Now I'm extremely nervous about doing this job myself. I understand all the articles I have read on doing this but still am very hesitant.
Hoping everything turns out ok for you KC.
1975 Widebody 911 3.2 Euro
Old 11-20-2002, 12:19 PM
RSW RSW is offline
RSW's Avatar
I would have to say yes it is possible to damage the valves if you turn the engine by hand but if your half carefull you shouldn't have a problem.
I followed the 101 book and turned the cams out of the way slightly so I could rotate the crank with a spanner. I did at one point feel some resistance but I was turning the engine very slowly, so all I did was back it of slightly and rotate the R/H side cam back to its original position and tried again.
There is no way I could have done any damage.
The only thing I did find was when turning the cams they are heavily sprung due to the valve springs, thus the cam wants to turn back to its original place.
1988 911 Carrera 3.2
Old 11-21-2002, 02:00 AM
