Replacing Original Shocks
I am in the process of replacing what I assume are the original shocks in my '83. After removing the top nut the shock did not even need my help to depress - it actually compressed under it's own weight? What driving characteristics should I have noticed with essentially no shocks? It seemed to drive OK? How much better can I expect it to feel and drive with new shocks (and new turbo tie rods)?
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Senior Member
Vance,
The difference will be dramatic! Mine did the same thing and there was absolutely no pressure left in the shock. Mine also "drove ok" but after the new shocks were in it was a 911 again! I pulled the cap off of the strut and the bits there just fell apart. Pls make sure you get all the old parts and oil out of the strut housing. Put Bilsteins in the car and took it out and could not get the smile off of my face for hours! If you are using gas shocks the ride height will increase a bit but in my case it went back down after a month or so. Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Joe - Thanks for the reply! What Bilsteins did you use - Sport's, HD's, combination? I am going back and forth between Sports' all the way around, or HD front, Sports' rear? Don't want it to rattle my teeth (or make the CD player skip), but I can deal with more of a sports car feel.
