1987 carrera,
The passenger side window air vents suddenly blowing hot air...I did not touch the levers in-between the seats...Idid not activate the heater dial between the seats...any thoughts? suggestions? |
the valve at/by the heat exchanger that brings heat into to the cabin can become corroded/stuck and cause this problem, even if the heat levers are off -- find it and, if sticky, lubricate so it closes easily and you should be all set.
Member 911 Anonymous
+1, flapper box under the car may be stuck open. Lube and work it make sure it looks like the driver side when you are done.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
hot air
Thanks guys...will follow up with your suggestions...where is that valve? how can I find it?
There are two of those, a hose attaches them to the two heat exchangers. They are next to the gear box. It is Pelican part # 911-211-013-00-M260
Jose
1970 911T - Garage Queen 1982 Audi UR Coupe Quattro - G.Queen 2011 VW Touran - Daily Driver Last edited by Jose_JGC; 08-14-2015 at 04:24 AM.. |
hot air
Thanks Jose...found them and lubricated both.
did it fix your problem?
hot air
I did not yet...but will test it later on.
I don't know about the later cars, but on my '70T, the 'doors' had plastic bushings in them that had worn out causing the problem you have.. Of course they aren't serviceable, but I took the heat doors off, carefully took them apart and had a buddy of mine make new ones out of aluminum.. Put them back together and they worked fine.. Plus a saved $$$..
Hopefully lubing them will fix your problem!!
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
hot air
It was the valve not opening...everything is back to normal! Thanks for your help.
