Tires for 9" Fuchs
Hi all,
Its been a long time since I've had the time to even begin thinking about my 911. I have an 84 cab and I got it while I lived in Monterey. I regeared the transmission myself, replaced the rear axles while I was at it, and have done a variety of things to the car myself - all with the help f the folks on this great forum. Anyway, I just bought some 9 inch fuchs and want to put these on the back. I have 7's which were on the back and am putting these on the front. Anyway, I was wondering if you guys could provide some input on what the tire sizes are that would be best for my back 9's. Its of course a narrow body 911
Mike
Old 08-26-2015, 03:48 PM
Rescuer of old cars
Arne2's Avatar
Best choice is 245/45-16. Not many choices left in that size, however. Some have tried 245/50-16, but those are considerably taller.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 08-26-2015, 03:57 PM
TheSt|G's Avatar
RE-11 is pretty much your last good street tire option.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 08-26-2015, 04:01 PM
Rescuer of old cars
Arne2's Avatar
And even those may be hard to find now, as I think Bridgestone has discontinued them as well.
2018 718 Cayman 2.0
Old 08-26-2015, 04:17 PM
patz's Avatar
That's why I sold my 16x8s, someone else's problem now. %^)
Old 08-26-2015, 04:26 PM
I bought a full set of Toyo R888 from tire rack today for just that wheel combo. I don't plan on doing any driving in the cold or wet so it should be an ok combo.
245/45/16 and 205/55/16.
1982 911 Targa, 3.0L ROW with Webers
Old 08-26-2015, 04:54 PM
Rescuer of old cars
Arne2's Avatar
8" aren't a problem, can still use 225/50-16 on those.
2018 718 Cayman 2.0
Old 08-26-2015, 05:39 PM
safe's Avatar
They do fine in moderate rain too, I wouldn't worry about using them on a daily driver.
Old 08-27-2015, 08:15 AM
Rescuer of old cars
Arne2's Avatar
But keep it in garage if the temp is much below 40°F. Even Toyo Summer tires are nasty in cold weather, based on past experience. I can't imagine that tires they sell as track use would be much better when the pavement is cold.
2018 718 Cayman 2.0
Old 08-27-2015, 08:57 AM
safe's Avatar
Below freezing all summer tires should be kept in the garage.
Old 08-27-2015, 09:41 AM
wrxnofx's Avatar
My '87 Carrera has 16x7 up front and 16x9 in the rear. Fronts are 205/55R-16 Bridgestone Potenza RE760 Sport SL, and the rears are 225/50R-16 Bridgestone Potenza RE760 Sport SL. Purchased from Tire Rack.
These tires work just fine for my needs.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 08-27-2015, 10:43 AM
Banned
I'm running Kumho Ecsta 245/50R-16s out back on my 9s. Kumho runs small, in both section and width, so it ends up that the rolling diameter is about right.
Old 08-27-2015, 10:56 AM
wrxnofx's Avatar
Do you have any spacers installed? Any problems with rubbing? Did you have to roll the fenders? I might have to consider these when I need tires again. Thanks for this info.
Old 08-27-2015, 11:12 AM
Banned
No to all, and if I wanted, I could actually go wider. The problem is that Kumhos run narrow, so it could be an illusion of room. If I got the RE-11s in 245/45, they might actually be right at the limit.
Old 08-27-2015, 11:30 AM
TheSt|G's Avatar
Yup. 8"s comfortably run 225 to 245.
Old 08-27-2015, 12:18 PM
Bill Verburg's Avatar
Bridgestone Potenza RE760 Sport SL 225/50 x16 are spec'd by the manufacturer for 6-8" wheels only
Bill Verburg
Old 08-27-2015, 02:18 PM
Kumho Ecsta 245/50R-16s There are many ECsta tires the first I could find in that size id the P31 which has a 25.7" OD when installed on a 7.5" wheel, they are only speced by the manufacturer for use on 7-8.5" wheels
For comparison a typical 225/50 x16 on a 7 is ~24.7" OD and a typical 245/45 x16 on an 8 is ~24.5" OD
the smallish 3 and 3.2 motors really like the shorter tires.
Bill Verburg
Old 08-27-2015, 02:24 PM
The whole point of spending the money fr 9s over 8s or 7s is to maximize performance
the wider wheel and wider lower 245/45 provide much more grip.
If you are into looks or just not into maximizing performance just stick w/ the 7 or 8
Bill Verburg
Old 08-27-2015, 02:26 PM
safe's Avatar
+1000!!!
I don't understand people sticking skinny tires on wide rims.... Looks and performs stupid
stupid.
Old 08-27-2015, 03:11 PM
thanks you guys! i actually found these 9's here on this forum. they were the same style as my 7's and they were gorgeous! I found a brand new set of 8's through Stoddard Porsche and would have gone with these but they weren't the same style. I absolutely cannot wait to get them on my car! Performance and looks!!!!!!! Sooooooo excited!
Old 08-27-2015, 04:01 PM
