brokke's Avatar
Spring plate angle
Hi,
I am replacing the rubber bushes of the rear springplates of my car. Before I removed the springplates I measured the angle the springplates are mounted. Left I measured 36.5 degrees and right only 34.5 degrees. Is this normal? Both torsion bars are 24 mm so I expected that the angle would be more or less the same.
Any ideas?
Peter
1972 911 2.4S
Old 11-18-2002, 11:57 PM
There are three factors that could make the spring plate angles uneven. 1) The rear end is not lifted at exactly the same height, side-to-side. 2) The wear on the torsion bars is not exactly the same. 3) The L/R vehicle ride height was set differently.
I would not worry about this. Use those angles as a reference point to reinstall the bars after you replace the bushings. If the heights are different, you may wish to readjust one corner.
Sherwood Lee
http://members.rennlist.org/911pcars
Early 911s Registry
Old 11-19-2002, 12:23 AM
Irrationally exuberant
ChrisBennet's Avatar
I suppose it is too late now, but prefer marking the position of the spring plate on the inner fender well. I clean the area behind the spring plate and put some wide (2"/50mm) masking tape on the body and scribe a line on that. You must clean the area for the tape to stick. Setting the torsion bars on an early car makes you really appreciate adjustable spring plates.
-Chris
Old 11-19-2002, 05:38 AM
taking those old bushings off is boatloads of fun. i reinstalled to stock t bars on their stops and came out on the money.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 11-19-2002, 08:23 AM
Early_S_Man's Avatar
Porsche Crest
Peter,
The angles ARE supposed to be the same on each side, with a small tolerance allowance. Your car was probably lowered or adjusted by someone who was a bit careless!
The factory spec was 36.5° to 37° for your car. The final check is for side-to-side ride height difference no greater than 5 mm between left and right sides!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-19-2002, 09:54 AM
Go to this page: http://www.vintagebus.com/cgi-bin/spring.cgi If your t-bars are stock, use the default t-bar size. Plug in the car's weight, and there's your angle.
Old 11-19-2002, 11:22 AM
brokke's Avatar
Thanks. I will make the angels the same on both sides and see what happens.
Peter
Old 11-19-2002, 12:09 PM
