Turn signal cancel adjust ?
The turn signals work fine on my 81 sc, except that after a left turn, I have to exaggerate the steering wheel correction to the right a bit, before the auto canceling of the switch kicks in.
Is this an adjustment ? or is a replacement part needed ?
Thanks for any feedback !
Old 08-27-2015, 03:14 PM
French Import
zippy_gg's Avatar
It is built into the hub of the steering wheel and if yours is far off you may have to move the steering wheel by one notch on the column and see if it solves THAT problem.
Then check if your front wheels are going straight when your steering wheel is "straight". If you are lucky that is the end of it. Else you will probably have to adjust your tie rods and wheel alignment. In that case you may want to decide if it is worth it or if you can leave with your current issue...
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 08-27-2015, 04:03 PM
wrxnofx's Avatar
The turn signal lever has a spring on each side to help with this. When I installed a new lever I unknowingly nudged one of the springs which disconnected it. I ended up with the same behavior for canceling the side that the spring was disconnected on.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 08-27-2015, 09:20 PM
If one side works and the other does not work as well .... but does sometimes work with a little "English" as they say ... Your probably in luck ... Go buy a can of corrosion X..... Careful though.... you will like this stuff so much you might want to drink some for your own body parts.... P.s. You can just spray it into the switch and it will be fine . Or you can go all out and pull the wheel clean things up.... Probably don't need to though..... bob
Old 08-27-2015, 09:47 PM
Thanks for the advice and insight folks.
As always, I will start with the simplest and least expensive actions first. That spring sounds interesting ....
Old 08-28-2015, 02:40 PM
The spring thing does happen .... but when it does you will know because that one side will be "dead"... not responsive under any circumstances ... yours , If I understand you, works reluctantly /intermittently ... So.... it is dirty and or needs lubricant.... It's not a matter of adjustment ....There is no adjustment.... bob
Old 08-28-2015, 07:52 PM
Driver
Noah930's Avatar
I had my turn signal cancel feature go weird on me once after I had been in there (sanding the corrosion off the little metal contacts for the highbeams). Can't recall if it was to the left or the right. But I took off the steering wheel to get to the switch in the steering column, fiddled around with it, and it all came back to work again. They're plastic indents or something like that, IIRC, so I suppose they could wear enough with time to necessitate replacement. I think mine was just hung up on something or other. A little cleaning did the trick.
1990 Black 964 C2 Targa
Old 08-28-2015, 10:29 PM
The Bavarian
On the back of the steering wheel hub, there is a ring with a perpendicular tab (sticking out) that operates the canceler switch. On my '80 SC, a previous owner had screwed that ring in the wrong position which resulted in the canceling happening on different angles left and right.
- Manfred
'80 911 SC Targa black/black
Old 08-29-2015, 12:54 AM
flashers cancelling
please refer to response # 8....the plastic part with the raised tab should be placed so that the tab is at 9 o'clock and the steering wheel is dead center.
Old 08-29-2015, 03:39 AM
Right Turn Signal Release Triggers Brights (when lights are on)
with my headlights on - when my right turn signal releases after the turn, my brights automatically come on (every time) it is odd and annoying - has anyone ever seen this before?
Old 08-29-2015, 05:07 AM
pete3799's Avatar
turn signal switch quick fix pictures
Pete
79 911SC RoW
Old 08-29-2015, 06:19 AM
Many, many thanks ... Will report results of fix attempt(s) later .
Old 08-29-2015, 03:56 PM
