El Duderino
tirwin's Avatar
Lightbulb Engine drop checklist - SC
Hey, all -
I was cleaning up the garage today and I came across my handwritten engine drop checklist. I know there are differences in model years, so I thought I'd post this for any SC owners out there.
- Disconnect battery
- Remove fuel pump relay
- Drain oil from sump
- Drain oil from tank
- Disconnect transmission shift coupler linkage (inside car)
- Disconnect 14-pin connector to fuse panel
- Disconnect 6-pin CDI from engine wiring harness
- Disconnect O2 sensor
- Disconnect transmission ground strap
- Disconnect hard oil line (right side of engine to thermostat)
- Disconnect and remove rubber oil line
- Disconnect battery to starter wire
- Disconnect clutch cable, arm & helper spring assembly
- Disconnect reverse backup switch from back of transmission
- Disconnect speedo cable from side of transmission
- Disconnect breather hoses
- Disconnect accelerator linkage bar
- Disconnect cruise control cable (if present)
- Unbolt axles from transmission
- Disconnect 6-pin CIS wire (back of engine bay near cruise servo)
- Disconnect fuel lines
- Disconnect vac lines
- Disconnect and remove rear sway bar
- Remove rear bumper valance (optional, depends on your engine drop method)
If A/C equipped:
- Remove A/C compressor belt
- Disconnect A/C compressor bracket & support compressor on side of car (be careful to protect paint)
Hope this helps... happy motoring!
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 08-29-2015, 12:04 PM
bcgreen's Avatar
I am wondering if pictures might even be more helpful.
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 08-29-2015, 12:34 PM
El Duderino
tirwin's Avatar
Probably, but all I have right now is my notes. Engine drop was over a year ago.
Old 08-29-2015, 12:41 PM
