HELP regarding heater control box cable
I am planning to replace the heater control box cable and cable guides on my '87 911 that has auto heat. I believe that the auto heat has only one looped cable that controls both R and L from the servo motor, but PP only shows a cable that specifies that 2 are required suggesting that this is not the correct part #. Sales at PP was unable to provide a definitive answer as was my local Porsche dealer. The cable guides part # is not a problem, but any help with the cable part # will be appreciated.
Peter
Peter 1987 Carrera Coupe 3.4 2003 Boxster S (SOLD) 1986 Carrera Coupe - (SOLD) 1984 944 - (SOLD) |
If you look at the parts diagram; if you don't have a PET program you can download your car's parts diagrams here:
PET there are 2 cable part numbers listed for the 1987, and 2 cables are required per the PET: 911-424-701-07, or 911-424-701-01 if you have an M637 option car. You could open up the console and inspect the cable(s) to insure this. ![]() Other helpful links on the heating: The Mysteries of Porsche 911 Auto Heat The No-Heat 930 - Questions Automatic heating system - Porsche 911 1984 1989 - Porsche Archives |
Thanks for you reply. PP sales does believe that the cable for the auto heat is a single looped cable which I have confirmed by opening up the console, but there is no different part # listed other than the cable where "2 are required". Nothing helpful in Porsche's car parts diagram.
Inquire about PN 911-424-701-02
Auto heat uses one looped cable, not two.
JR |
Try 91142470108
Thanks for your help.
Will follow up with your suggestions.
F/U
911-424-701-02 auto heat single looped cable that is designated for '78-'86, but I am unaware that there was any difference in auto heat in '87' Cost $12 (O.E.M) $28 (genuine Porsche) 911-424-701-08 long looped cable designated for '87-89, but cost is $60 (genuine Porsche) I am going to order the $12 cable believing it will also work on my '87. Thanks again. You guys found what PP and Porsche couldn't.
