-   -   Smoke out of heat exchanger after reinstalling engine (http://forums.pelicanparts.com/porsche-911-technical-forum/881506-smoke-out-heat-exchanger-after-reinstalling-engine.html)
Christien 09-02-2015 10:40 AM
I just had the engine out to replace the rear main seal and oil cooler seals because of copious oil leaks. Back in and started, after running for maybe 60 seconds I noticed a lot of smoke coming out of the passenger side heat exchanger (only, not driver's side). None of the heating hoses are connected, so it was coming out of here:
http://forums.pelicanparts.com/uploa...1441215565.jpg
Should I be concerned, or is it likely just oil that's seeped places it shouldn't go while sitting? (2 weeks) It's more smoke that I would usually see on startup.
Jim Richards 09-02-2015 10:46 AM
I'm thinking seepage. After it sits for a while, long enough to completely cool down, try starting again and look for smoke.
CCM911 09-02-2015 11:46 AM
DOn't give it a second thought. Just run the engine for a bit and it will stop. Who knows what could have taken residence down there. Every time I put my engine back in there is some funny smelling smoke for the first few minutes of running.
Now if the smoke keeps up, it will be a different story.
theiceman 09-02-2015 01:13 PM
i dont have any pipe like that running underneath my timing box like that is that particular to your year ?
anyway who cares ..who needs heat at 29C today ..is it really September ?
iceracer83 09-02-2015 01:39 PM
Oil can seep between the exhaust tubes and heat exchanger shroud and collect inside the shrouding. Once the accumulated oil burns off, no more smoke.
I had a loose cross over pipe on my '74 that dripped a lot of oil into the driver's side exchanger. Oil poured out of it when it was removed for cleaning.
Jay
Christien 09-02-2015 01:45 PM
I ran it a few more minutes - still a bit of smoke, but a lot less. I'll take her out for a good rip and see if that gets rid of it. The good news - no oil drips under the car!
JOHN21BLACK 09-02-2015 01:52 PM
Those are early style SSI headers. Mine run the same way under timing housing.
Bob Kontak 09-02-2015 05:15 PM
Dimes to doughnuts it goes away.
DRACO A5OG 09-02-2015 05:30 PM
+1, When I reinstalled my exchanger after replacing my return tube seals, it smoked then disappeared quickly.
