<insert witty title here>
Christien's Avatar
Smoke out of heat exchanger after reinstalling engine
I just had the engine out to replace the rear main seal and oil cooler seals because of copious oil leaks. Back in and started, after running for maybe 60 seconds I noticed a lot of smoke coming out of the passenger side heat exchanger (only, not driver's side). None of the heating hoses are connected, so it was coming out of here:
Should I be concerned, or is it likely just oil that's seeped places it shouldn't go while sitting? (2 weeks) It's more smoke that I would usually see on startup.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 09-02-2015, 10:40 AM
Bandwidth AbUser
Jim Richards's Avatar
I'm thinking seepage. After it sits for a while, long enough to completely cool down, try starting again and look for smoke.
Jim R.
Old 09-02-2015, 10:46 AM
DOn't give it a second thought. Just run the engine for a bit and it will stop. Who knows what could have taken residence down there. Every time I put my engine back in there is some funny smelling smoke for the first few minutes of running.
Now if the smoke keeps up, it will be a different story.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 09-02-2015, 11:46 AM
theiceman's Avatar
i dont have any pipe like that running underneath my timing box like that is that particular to your year ?
anyway who cares ..who needs heat at 29C today ..is it really September ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-02-2015, 01:13 PM
Iceracer
Oil can seep between the exhaust tubes and heat exchanger shroud and collect inside the shrouding. Once the accumulated oil burns off, no more smoke.
I had a loose cross over pipe on my '74 that dripped a lot of oil into the driver's side exchanger. Oil poured out of it when it was removed for cleaning.
Jay
Old 09-02-2015, 01:39 PM
Christien's Avatar
I ran it a few more minutes - still a bit of smoke, but a lot less. I'll take her out for a good rip and see if that gets rid of it. The good news - no oil drips under the car!
Old 09-02-2015, 01:45 PM
JOHN21BLACK's Avatar
Those are early style SSI headers. Mine run the same way under timing housing.
Old 09-02-2015, 01:52 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Dimes to doughnuts it goes away.
1981 911SC Targa
Old 09-02-2015, 05:15 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, When I reinstalled my exchanger after replacing my return tube seals, it smoked then disappeared quickly.
'85 Carrera Targa
PCA/POC
Old 09-02-2015, 05:30 PM
