Rear Turn signal interior clear lens
Hi all,
First time poster, long time lurker. I've recently begun the process of replacing all of the weatherstripping on my 83 SC Cab. Today while taking apart my rear tail light, I noticed that the clear turn signal lens (behind the main lens, inside the housing) had a really shoddy repair to it by the previous owner and was barely hanging on. I'm looking to replace it but cannot find any reseller for just this piece, it seems that the only solution is to buy an entire new housing. Anyone run into this before or know where I might be able to find a replacement part? Thanks in advance.
1983 911 SC Cab |
Are you tlking about the reflector that is clipped in there?
78 911 st backdate 87 944 00 996 |
Burnin' Rubber
I'd like to know a source for that inside reflector piece too!
Yes, exactly. Except rather than being clipped in, it is attached by three pegs (which are broken and the cause of my issue). Here's a picture of the broken reflector in question.
You can see the black weatherstripping adhesive the previous owner used to try and keep it in place. Thanks for your help!
1983 911 SC Cab |
Picture link didn't seem to work.
1983 911 SC Cab |
Member 911 Anonymous
Got mine from 20th Street Auto. They did not like breaking up the set but did it anyways. Need to call and ask.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Burnin' Rubber
These things crumble better than crumb cake
Found one..
There is at least one on eBay under item number 131570890686
Undocumented User
It's just a refractor lens, you can use anything in there really. People here have even used an overhead florescent lighting refraction pannel piece cut out to fit.
Thank you all for your thoughts and recommendations!
1983 911 SC Cab |
| Tags |
| 1983 , 1983 911sc , part number , tail light |
