distributor rebuild
Hello,
![]() i 'm planning to repair my ignition distributor 2.7l). I have seen that ************.com sell parts for the rebuilding. What's your experience with this company? I have too readed a lot of values for the radial and axial play? Could you say me wich play is acceptable for the distributor? Thank you for your answer. ![]() canaille911 (from Belgium) |
Member 911 Anonymous
I highly recommend them, they helped me rebuild my dizzy.
Vertical play should be no more than 0.5MM ( up and down ) You must have no radial play and it is normal to have some drag as you spin the shaft. Get the bronze bearing washer and appropriate amount of shims and two fiber washers. ![]()
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Highly recommend. Very helpful and they have hard to find parts.
very cool shop. where else can you find advance springs?
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
************ is a great shop.
Kurt is great!
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
What about oil?
I understand you should occasionally oil the dizzy...what kind of oil, how often and where?
Extremely Yellow ’74 Targa 2.7 L - aka WIFE’S BANE |
ive heard motor oil on the felt pad at the top, a few drops
Motor oil. Some people prefer 3-in-1 oil. On the felt pad under the rotor. With every oil change.
should be oiled under the felt
Dizzy Rebuilt
Purchased parts to rebuild my distributor from PartsClassic - they were very helpful.
83 SC Ignition Distributor Bushing Replacement Good luck, Gordo
Don "Gordo" Gordon '83 911SC Targa |
Hard to beat ParstKlassik! Kurt and Sarah are very helpful and easy to work with. Kurt loves what he does and it shows. Sarah is customer service personified.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
