2016 991 GTS 2 PDK. There is a continuous low beeping sound between 2 km/h and around 8 km/h. The sound is heard not just at startup but anytime the car is in that speed range both forward and reverse. Beyond that the sound seems to go away. I took it into the dealer who did a full systems check and reported that everything is absolutely fine with the car. They did acknowledge hearing the beeping sound and are going to check other 991 GTSs to see if they can figure out what it is. Could you tell me what it could be? Fyi, I´ve had the car for just over a month and I started noticing this beeping sound a couple weeks back.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Haven't seen these cars yet, so I can't be much help.
I opened a post in our forums. A Pelican community member may be able to answer your question. - Nick |
