-   -   right or wrong? (http://forums.pelicanparts.com/porsche-911-technical-forum/88195-right-wrong.html)
pwd72s 11-20-2002 02:32 PM
right or wrong?
"I even approve upgrading from 2.4 to 2.7 because you can go back to original pistons & cylinders. Cutting off original rear fender is not reversible - it's a permanent loss. "
The above was posted on another board. Silly me, I always thought a 2.4 case had to be machined to accept the larger 2.7 p&c set...one reason I never did it. So, what's the story?
Rot 911 11-20-2002 02:38 PM
Ok was this Ian or Tabby that posted that bit of drivel?
Early_S_Man 11-20-2002 02:45 PM
Paul ... just as you suspected, after a 2.4 case is opened up from 92 mm spigots to 97 mm for the 90 mm 2.7 Nikasils ... there isn't much 'shelf' space left to support 2.4 84 mm cylinders! Definitely NOT reversible!
pwd72s 11-20-2002 03:00 PM
Hoot! You're pretty good Kurt, it was Ian...
