pwd72s's Avatar
right or wrong?
"I even approve upgrading from 2.4 to 2.7 because you can go back to original pistons & cylinders. Cutting off original rear fender is not reversible - it's a permanent loss. "
The above was posted on another board. Silly me, I always thought a 2.4 case had to be machined to accept the larger 2.7 p&c set...one reason I never did it. So, what's the story?
Old 11-20-2002, 02:32 PM
Friend of Warren
Ok was this Ian or Tabby that posted that bit of drivel?
Kurt V
Old 11-20-2002, 02:38 PM
Early_S_Man's Avatar
Porsche Crest
Paul ... just as you suspected, after a 2.4 case is opened up from 92 mm spigots to 97 mm for the 90 mm 2.7 Nikasils ... there isn't much 'shelf' space left to support 2.4 84 mm cylinders! Definitely NOT reversible!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-20-2002, 02:45 PM
pwd72s's Avatar
Hoot! You're pretty good Kurt, it was Ian...
Old 11-20-2002, 03:00 PM
