Help with Part #
Does anyone know what the part # is for the bracket that holds the Beru wires on the passenger side of the engine??? PET shows the drivers side but not the passenger side.
Thanks!!
Old 02-25-2022, 04:31 PM
proporsche's Avatar
1st you have to mention what 911 it is for and even show the pet picture to be helped
to insert a picture "go advanced "and there is a blue line to be used for pics
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-25-2022, 11:59 PM
I appreciate the guidance. To be clear, the issue is that I cannot find it in the PET for my 1984 911 3.2. Its the two ignition wire brackets on the passenger side and the little bracket that holds the thermostat wire on the shroud that I am looking for.
Old 02-26-2022, 07:20 AM
proporsche's Avatar
well the answer is simple.Only 1984 spark plug wires were routed around the 4 5 intake manifold.Therefore no little bracket were used..looks like this
[IMG]https://www.autorevue.cz/GetFile.aspx?id_file=142413943[/IMG]
Ivan
Old 02-26-2022, 08:21 AM
Thanks Ivan! Much appreciated
Old 02-26-2022, 08:27 AM
