84 3.2 plug recommendation stock street engine
Hello All....been awhile since I changed plugs, searched forum but no clear recommendations. I have used NGKs in the past, but now there are many options and ranges available. Car has 108k, stock, street only. Which plugs?
Thanks, Dave
1984 Porsche 911 Carrera 2002 BMW R1150RT 2013 Audi A4 2020 Ford F150 4x4 |
abides.
Ngk BPR6ES
Graham 1984 Carrera Targa |
Recreational User
Use whatever the owners manual recommends. For an 86, it's WR7DC, Bosch copper. I would assume the 84 is the same, but check the manual.
Member 911 Anonymous
Copper either NGK or Bosch
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
All manuals say Bosch WR7DC. I would like to use NGK, but can only find BPR6 ES. Is the heat range that much different, or are these two interchangeable?
Just have had great luck with NGK. Thanks, Dave
Diss Member
The NGK BPR6ES is the first choice of a major portion of "those with an educated opinion" on the Carrera. It will be one more thing you don't have to think about on the car.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
