Weekend road trip, may need heat
Bride and I heading to upstate New York next weekend for the Hemmings Concours.
It can be cool this time of year in New England and upstate NY. My heater flapper boxes are pretty bad, they won't shut off so I have just left the hoses of all Summer. I did hook them back up today and went for a toasty drive. Some ideas I'd like to pass by the board. Since it is so hard to hook the hoses back up unless the car is up could I leave them hooked up and just disconnect the black plastic hose from the outlet of the fan housing to the booster fan if it's warm out? Would this force too much of the heat from the heat ex changers back in to the engine compartment and cause the car to run hot? I have a plastic container that fits perfectly over the fan outlet, but of course same questions arises, will that return too much heat to the exchangers? Your thoughts please.
G. Hamilton '82 SC Guards Red-2nd time owned-Now sold "Bumerang" '70 TR6 N of Boston Last edited by ghamilton; 09-18-2016 at 04:58 PM.. |
I wouldn't disconnect at the outlet of the engine fan - that air does serve the functional purpose of cooling the exhaust.
Fleabit peanut monkey
I would craft a plug system inside the engine compartment.
Whatever that may be. It should be simple but unpretty. Soup cans, etc. to plug but then the ability to re-connect. Do not allow the precious bodily fluids of the BIG fan to escape through the loose heater hoses in the engine compartment. Make the air pass over the oil cooler without escaping. Plug the heater flow to the exchangers when warm out. Connect when cold.
1981 911SC Targa |
I see no way German engineers would have designed a system that requires external airflow over the exhaust pipes to maintain its integrity.
1981 911SC Targa |
Mighty Meatlocker Turbo
Bob, I've never tried it with my Turbo (don't see how it would be any different, however, since the design is the same), but way back in my early 20s, I had a 914 that I took on a test drive after doing some work on it - had left the air supply hoses disconnected from the heat exchangers, and they got so ungodly hot that the pinging sounds, and odor (like superheated metal - not burning oil) coming off of them when I parked basically scared me. In other words, the exchangers get way too hot if air is not blowing through them when the engine is running. |
Like this?
G. Hamilton '82 SC Guards Red-2nd time owned-Now sold "Bumerang" '70 TR6 N of Boston |
I would not disconnect hose. Heat exchanger get realy hot without air flow even with fan noy running you have air flow from alternator fan.
The heat exchangers don't need air. They just get hot...may actually help to burn oil residue off
I often don't have air to my SSIs for the whole summer season |
What do you when you remove heater, but not heat exchangers? Unvented heat exchangers cause engine wear? |
Where's the concours, I live upstate have not heard about it?
I had this same problem with the 83 when we first got it. Lifted the car some wd40 sandpaper and a dremial tool I freed them up. With my son moving the levers finding where they were sticking we got them working and there still working. Takes a little time but you may be able to clear them.
1986 Porsche 911 Targa 1983 911 sc 2015 WRX |
Fahren mit dem Wind.
It's the Hemmings Motor News Concours held in Sarasota Springs north of Albany.
https://www.hemmings.com/events/concours
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net) Caregiver to: 1983 911 SC Cabriolet - Fahern mit dem Wind. (Moss Green Metallic over Champagne and Brown Leather) |
Boxes open and close, have new cables, but the flaps and parts of the inside of the boxes are missing.
Can't shut off the heat.
new boxes are pretty cheap these days
