Engine Mount/1st Gear
On my 86 Cab, It is difficult to force the shifter into 1st or 2nd gear when the car is on a flat road. I've noticed that if I'm coming to a stop sign on a steep hill, though, I can shift into 1st or 2nd like it was butter.
So, my thought is that something is impinged when the car is flat and isn't impinged when the engine falls back a bit on a hill.
If that's the case, is it possible to just loosen up the engine mounts or something and pull it back a millimeter? Is it possible to do that without the engine falling out of the car?
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 09-12-2015, 08:56 PM
sugarwood's Avatar
Do some searching about adjusting your shift coupler and replacing bushings.
1986 Bosch Icon Wipers coupe.
Old 09-12-2015, 10:26 PM
wayne robson's Avatar
try this.
Hi Pstallo,it will probably be your shift rod coupling .The 2 bushes inside coupling
will be worn out fore and aft and sideways when they are really worn out ,example by
quarter inch play this alloys the rod to move up and down so much it stops the selection
in both 1st and 2nd gear really bad. Go to our host sight ,the kit is cheap to purchase
and they have excellent instructions on how to repair,its easy.You can lift carpet in front of your rear seat on tunnel remove 4 screws, put metal cover a side,grab hold of the shift rod and push - pull,should not rattle or move,you will see if it worn out .good luck.
Old 09-13-2015, 04:07 AM
wolds's Avatar
When you are in gear and just cruising along do you notice any movement in the shift (front to back) when you let off and then punch the throttle again?
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 09-13-2015, 05:05 AM
Hi wolds what does this movement indicate
Old 09-13-2015, 05:39 AM
Also
Also check that the clamp and bolt has not came loose on the shift rod at the coupler
alloying it to move forward and back, so it will not alloy you to change gears.
Old 09-13-2015, 03:45 PM
I actually replaced the bushings last year and had the shifter coupling adjusted by a Porsche mechanic. I also replaced the entire shifter itself with a JWest shifter. Before that, shifting was pretty much random, so it's tremendously better than it was.
It's just takes a pretty solid amount of force to get it in gear when the road is flat or headed downhill and shifts easy if I'm going up a steep hill. I thought it might indicate a simple fix like shifting the engine back a millimeter or something.
Old 09-13-2015, 08:05 PM
How old are the engine mounts? If they've gotten soft from age or started to sag, the uphill/downhill difference in shifting could just be from the drivetrain moving more than its supposed to.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 09-13-2015, 08:59 PM
wolds's Avatar
It indicates that there is wear in the mount. Some play is normal.
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 09-14-2015, 04:46 AM
The engine mounts are original 1986. I figured they would be pretty worn.
Can the engine mounts be changed easily or is that an 'engine-dropper' type of job? The shop handbook only references removing the engine mounts as part of removing the engine to work on it.
Old 09-14-2015, 07:48 PM
ROW '78 911 Targa
timmy2's Avatar
With a floor jack you can change the mounts out one at a time. Like in a partial engine drop.
When doing the rear ones make sure to loosen the trans plate bolts to allow for movement before tightening everything back up.
I did mine that way.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-14-2015, 09:44 PM
sugarwood's Avatar
I thought you don't want anything to move when swapping out the engine mounts....
Old 09-15-2015, 05:02 AM
wolds's Avatar
you're doing them one at a time so that nothing moves.
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 09-15-2015, 06:16 AM
ROW '78 911 Targa
timmy2's Avatar
Loosening the tranny mounting plate may allow some movement of a few millimeters, but it is necessary so you can get the bolts back in without messing up the threads.
(Ask me how I know!)
The new mounts may cause slight position shifting as well.
Make coupler adjustments after if needed.
Dennis
Old 09-15-2015, 08:47 AM
