Designer King
Paulporsche's Avatar
Front Sunroof Drain Discharge Location
I am trying to clear the front sunroof drains on my '77.
Where do the front drains for the sunroof discharge? I have a flexible clear plastic tube coming into the frunk from the inner fender area above the battery but it just terminates inside the frunk. It seems that, if this is the drain tube, it should exit to the outside. If correct, where is the access for this?
And shouldn't there be a similar hose and exit for the passenger side?
Similarly, where does the battery breather hose exit the frunk? The battery is in the factory location.
A description would be great, but a picture might be even better.
Thanks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-29-2018, 09:17 AM
Banned but not out, yet..
RSBob's Avatar
Run some trimmer line through the roof drain holes to clear. The fronts exit either between the door and fender or the wheel well. Do not recall. But trimmer line will tell.
Old 09-29-2018, 09:37 AM
sunroof drains
here are a couple of pictures that "Rust Heap" sent me
Lorne M.
83 SC
Old 09-29-2018, 09:40 AM
Designer King
Thanks guys.
Looks like I couldn't see all that, since I can't get my doors fully open in my garage.
Lorne,
What is the plastic hose above the drain tube in your driver's side shot?
I'm wondering if the hose that goes into my frunk is a vent for something else. Maybe for an emissions cannister?
Paul
Old 09-29-2018, 09:56 AM
RSBob's Avatar
Probably for your brake fluid over flow. Trace the line back
Old 09-29-2018, 09:58 AM
Originally Posted by Paulporsche View Post
Thanks guys.
Tube for frunk release cable is my guess.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 09-29-2018, 10:59 AM
its the plastic tube cover for the fuel filler door release
Lorne M.
83 SC
Old 09-29-2018, 01:51 PM
Designer King
Got all 4 drains clear. I used a single wire from some 14/2 Romex cable. It was vinyl coated and flexible, yet rigid enough to push through the clogs.
Now I just have to figure out the tube going through the driver's side of the frunk. Right now I'm thinking it may be for the battery breather.
Paul
Old 09-30-2018, 02:04 PM
can you post a pic of the problem hose?
Lorne m.
83 SC
Old 09-30-2018, 04:03 PM
Designer King
Thanks Lorne. I'll try to get something soon.
Paul
Old 09-30-2018, 06:03 PM
