Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Fixing a pesky leak on the transmission shift fork cover
I've been having a small leak at the shift fork cover on my 915. After researching, I figured I would give it the 'shotgun' approach and attempt the impossible: Make my own gasket out of slightly thicker material designed for use with oil as opposed to paper (or what seemed like paper). And...resurface my shift fork cover And...use a gasket sealant
so I went to O'reily's and got some gasket material:
went to harbour freight and got a punch kit:
drained the oil, removed the cover and was able to salvage the old gasket to use as a template. I soaked the paper gasket in brake cleaner to remove the transmission oil. it dried out quite nice and looked like i could reuse it if I wanted to.
I used the punch set and a box cutter to trim out the gasket
After double nutting the studs on the cover and removing the locator pins, I then laid out some wet/dry sandpaper at 180 grit (I think) and used the bench to flatten out the cover and remove some of the imperfections with WD40 as a lube.
before:
after:
so then i put it all back together with blue locktite and sprayed the side of the new gasket that will be touching the cover with K&W Copper Spray.
here it is ready to re-install:
Its been 24hrs with no drips runs or seepage. I hope this helps anyone out with an annoying leak from this area. I do have some concern as the gasket material is roughly 3x as thick as the paper that i pulled out, id want to say 1/32th of an inch? Probably not an issue.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 10-29-2015, 12:06 PM
The usual problem with the inspection plate is the fork coming loose, making gear selection very difficult.
A major builder of 901/911/915 suggest once the fork is found loose, replace the piece because the studs will no longer hold.
Bruce
Old 10-29-2015, 12:33 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Nice job.
Just keep an eye on it after you have run it a while and advise.
Operational heat will be the real test.
1981 911SC Targa
Old 10-29-2015, 02:18 PM
pete3799's Avatar
I made a gasket for mine 3 or 4 years ago. Put it on dry and have had no trouble with it.
Pete
79 911SC RoW
Old 10-29-2015, 04:55 PM
Black and Blue
Kemo's Avatar
I will be exercising the new gasket at Texas World Speedway this weekend. Will update afterwards. Just had a Giken OS Limited Slip installed along with a full rebuild, so kinda giddy right now. Looking forward to some track time...
Kemo
Old 10-30-2015, 07:16 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Bruce
Agreed with Bruce and the solution to that is thru-bolt the cover plate like this
third gear squeal
Or just get a new billet piece from CMS or WEVO. A bit spendy, but nice parts and nice guys to deal with.
Go easy on the refreshed trans.!
Kevin L
'86 Carrera "Larry"
Old 10-30-2015, 09:00 AM
gtc gtc is offline
abides.
gtc's Avatar
A friend of mine had his shift fork come loose. I took it out and applied some Loctite 574 between the fork and the cover plate, since 574 is supposed to have good shear strength. Sealed it up with a factory gasket and threebond, and it's been good ever since.
Knock on wood.
Graham
1984 Carrera Targa
Old 10-30-2015, 10:16 AM
Bob Kontak's Avatar
Does Danny Ochoa still run his white 911 there? Last I saw him was late 90's running at TWS.
We worked together in the exciting world of bean counting.
1981 911SC Targa
Old 10-30-2015, 11:55 AM
