Motor Oil
Does any one have a suggestion on what motor oil to use for a 1977 911
Senior Member
Yes, please have a look at the Ultimate Oil Thread posting.
Oil is so subjective a topic that it is a bit of a third rail on this 'Board. As a rule, go with an oil whose content supports direct tappet operation as seen in our air-cooled cars. Generally Brad Penn or Valvoline VR-1.
'78 Targa in Minerva Blue |
Banned
Motul 300v4T, 15w50
Member 911 Anonymous
oh no, not again :-(
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
you need a shovel. Cause this thread is going to dig up a lot of old *****
1984 Carrera 1985 Vanagon Westfalia 2009 Audi A3 2015 VW Jetta 2016 Sprinter |
Keep it simple.......
Morde, Make your decision easy and simple. You could not go wrong using these oil brands (Brad Penn or Valvoline VR-1). Like what had been said it is very subjective. There are other oil brands people use and their choices vary. Each of these brand names are formulated differently using an assortment of petroleum additive products. We could spend days arguing its merits and at the end you will be more confused. Take a deep breathe and decide. Tony Last edited by boyt911sc; 09-28-2015 at 09:15 AM.. |
For VR-1 in a mixed climate Chicago area, what Grade 10-W30
Since VR1 can't be found on sale anymore and stocked up, my next change will likely be Shell Rotella.
Diss Member
![]() 10-30 might be good at extended use below zero but it is never recommended for any normal use in an air cooled 911. Use 20-W50 (or 15-W50 in the synthetics that are recommended.) The two common recommendations already listed: Brad Penn or VR1 Other useful choices are Motul, Royal Purple, and Redline. (A little more polarization on this list...) Brad Penn is the first oil I have seen that gives a noticeable improvement in wear when you run it through oil analysis. (I haven't tried VR1. Why bother after seeing what Brad Penn does?)
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. Last edited by Quicksilver; 09-28-2015 at 09:14 AM.. |
Thanks all a bunch very helpful!!!!!
Sam |
