Two misc. brackets, 82 SC: where do they go?
I'm in what I hope are the final stages of reassembling an 82 SC that I bought pre-disassembled. Most of the "where does this go?" questions I've been able to answer by searching PP threads and studying the PET. Here are two misc. backets I have yet to identify. The one that looks like a strap is similar to the pair that go between the steering rack and sway bar mounts, but it is not one of them. It has a nut with a collar machine to fit with the hole at one end of it. The other is a plate with two 8mm studs tacked to it, with two holes for 8mm bolts on the other side. Thanks in advance for your help, John.
Old 09-26-2015, 11:50 AM
Misc. Parts.......
The square plate is the ignition coil bracket mounted on the alternator housing. The other bracket looks like for the AC (not sure) because I removed mine a few decades ago. Someone might know more about it.
Tony
Old 09-26-2015, 01:45 PM
Been here a while
Tony is right. You need to lower the coil for it to clear the ac condensor on the deck lid. The other bracket mounts to a threaded insert near the oil pressure sender and attaches to the base of the compressor mount.
Old 09-26-2015, 02:04 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Yes AC
911-126-124-01
1981 911SC Targa
Old 09-26-2015, 02:06 PM
Thanks Gents! Much appreciated, John
Old 09-26-2015, 06:13 PM
