Burnin' Rubber
Koizumi's Avatar
Crushed Oil Line Question
Oil temp seems to be normal at 90F ambient outside with the needle hovering around the first gauge tick. With the AC on in obnoxious stop & go Friday afternoon traffic, it gets close to the second gauge tick. It never reaches the 2nd tick but it gets close.
Oil is BP 20w-50
I've got the older Carrera oil cooler in the wheel well, the non-fan version (and obviously not the silly trombone style).
I have the typical partially crushed oil line near the jack point issue. I'm wondering if this partial crush is an issue. My oil temp is always at or slightly below the 1st tick with no AC and 80F ambient outside. AC and hotter ambient temps push it up to near the 2nd tick in stop & go traffic as mentioned above.
What do you think about this crushed line and should it be repaired ASAP or are my temps normal for the ambient outside temps?
Old 09-25-2015, 04:20 PM
dos531's Avatar
Replace it and get a fan on the cooler.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 09-25-2015, 04:36 PM
Rescuer of old cars
Arne2's Avatar
Your pipes are bit worse than the small dent in mine, but your temps sound totally normal to me, assuming your gauge is reasonably accurate.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 09-25-2015, 05:04 PM
wayne robson's Avatar
My opinion is the partly crushed pipe is not a real problem
so changing that wont make any difference.
Old 09-25-2015, 05:07 PM
Fleabit peanut monkey
Bob Kontak's Avatar
There is a thread on "popping" out the dents with air pressure and a propane torch.
I would not fret the temps but do some research on pulling the lines in your leisure (this will be the hard part) and then configuring the pressure system.
I'll find the link and post.
Here it is:
Fixed my Crushed Oil line for $5 and a beer.
1981 911SC Targa
Old 09-25-2015, 05:15 PM
nene's Avatar
You do not need to replace and add a fan. I and a ton of other people are in the same boat. I myself am in the same situation and have not had any problems or issues with the temp, even in the summer here in Cali.
Old 09-25-2015, 07:21 PM
78-911SC's Avatar
+1 on nene
PJ
78 911sc Targa
70 911T
Old 09-25-2015, 08:38 PM
Burnin' Rubber
Koizumi's Avatar
Thanks for the answers and suggestions. At this point I'll wait on it. My OCD will eventually get the best of me & I'll try out the propane compressor technique. Seems easy enough. The endless summer heatwave continues onwards here....
Old 09-28-2015, 12:22 PM
dos531's Avatar
You dont NEED to, but its definitely worth the minimal expense and time. Up there in Sonoma is a bit different than down here with LA heat and traffic. My 930 has one of these set to turn on about 205f
http://www.elephantracing.com/oilhandling/fans.htm
Ducati 748R
Old 09-28-2015, 12:55 PM
sugarwood's Avatar
Is adding a fan to the oil radiator a straight forward project?
I'd be interested in making that upgrade if it's commonly accepted as good.
Is the $160 link above the only game in town?
1986 Bosch Icon Wipers coupe.
Old 09-28-2015, 06:19 PM
dos531's Avatar
That's the most bolt-on straightforward install, but piecing together a kit is easy. Just an electric fan of the proper size, a thermoswitch, and some wire.
It's so commonly accepted as good that porsche installed them after 1986
Ducati 748R
Old 09-28-2015, 09:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
K,
Just pop it out, take care the brass is really soft. I used a bicycle pump. Worked until I burned throw it, used copper pipes and soldered it and held up fine until I got the finned lines and their fan . Definitely cooler.
'85 Carrera Targa
PCA/POC
Old 09-28-2015, 10:44 PM
sugarwood's Avatar
At $160, it does seem expensive for what it is.
What do you think piecing a kit together would cost?
I will look for a thread where someone's done that.
Old 09-29-2015, 02:46 AM
Burnin' Rubber
Koizumi's Avatar
Out of curiosity, would a fan install help cool the early Carrera non-finned tube cooler (not the trombone style). I thought about adding a fan but my cooler isn't finned so I'm not sure if it would make much of a difference.
Old 09-29-2015, 07:43 AM
DRACO A5OG's Avatar
My 2 cents. It will help but very little as the area of the older cooler has less surface area to cool it down adequately, but it will help, especially stuck on the freeway parking lot. Flow is what is critical, better the flow faster the cooled oil can get back into the engine to do it's job.
Maybe a aux fan in the engine bay?
Side note, how is your AFR, if on the lean side it will burn hotter??? PM me and I will explain.
'85 Carrera Targa
PCA/POC
Old 09-29-2015, 09:16 AM
sugarwood's Avatar
To answer the OP's question, I have rarely gone near the 2nd tick.
Then again, I don't seem to drive in stop and go traffic, nor do I turn on the AC, nor do I drive when it's crazy hot out, either.
I would still get an estimate on repairing it, just for the peace of mind.
Old 09-29-2015, 12:00 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
I will say that in my 964 the fan does a very good job keeping the temps under control but if the car gets too hot--the fan will not bring the temps down. Many 964 owners install a switch for this very reason. If you encounter a situation where you know airflow will be reduced for an extended period, you can switch the fan on BEFORE the oil becomes too warm.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 09-29-2015, 02:28 PM
Sugarwood
Does your "Normal" range of 190-248F apply to my mag case 2.7L with SSI?
1976 911S, sleeping for 13 years, back to life in 2013!
Old 09-29-2015, 06:29 PM
Burnin' Rubber
Koizumi's Avatar
Mine never gets above the 2nd tick. It gets close on days of 95F and stop & go with full AC. Under normal circumstances, it sits at the 1st tick... 80F, no AC
Old 09-29-2015, 06:32 PM
sugarwood's Avatar
I just pasted that graphic from another thread.
Old 09-29-2015, 06:40 PM
