porsher
No charging
I have a 95 993 3.6 transplanted into an 86.
A couple of weeks ago I noticed that after starting, the volt meter remained at 11 V and took a few minutes before it jumped up to 14V. Charging light behaved normally: on with ignition (nice and bright), out as soon as engine starts. Tired voltage reg I thought. So I purchased a Bosch rebuilt alternator to last another 20 years. Installed same. No improvement GAAAAA. DMM agrees: 11.9 V off, 11.5 V engine running. (Crappy DMM btw) Charging light normal. Quick road test and no voltage jump! 11.5 V the whole time. Today I checked wiring: engine ground nice and clean. 14 pin connector (blue wire) clean up and spread pins a bit. Still no charging? ![]() What next?
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Normal start, crank?
Defective DMM, or poor measuring point... Possibly a shorted battery cell. Normal charging voltage ~13.50V minus cell value, 2.15V, = 11.35V. |
porsher
Thanks for the info.
I got some better data. Battery was charged overnight. At rest 12.55V, engine running 11.98V As a control I measured the Tundra Rest 12.64, engine running 13.54 This suggests my DMM can be believed. Measurements are taken directly from battery terminals. Engine cranks and starts normally.
ROW '78 911 Targa
Alternator charges battery through the connection at the starter.
Check to ensure it is tight and clean. Disconnect negative at battery when doing so.
porsher
However, the yellow start wire was about ready to fall off. I re-terminated and it's all tight now.
Fleabit peanut monkey
All ok?
1981 911SC Targa |
New-ish 911SC Targa Owner
Ground from motor to chassis. Add a temporary ground in the form of a jumper cable from metal on engine to metal on chassis and check voltage at battery again. If it improves, replace ground strap.
porsher
Yellow wire sends power to the solenoid, unrelated to charging prob.
Just aggravation avoidance. Charging is still FUBAR. I will try temp ground cable
try the tundra battery in the 911 and vice versa.
My bet is now more solidly on shorted battery cell. Build up of plate metallic debris in the bottom of the battery, (intermittently) shorting cell(s) is very common failure mode. |
I am not going there yet.
My bet is that the install of the alternator may be wrong. I don't know why the charge light would not be on. However, always go to the last place you put a wrench on the car. First post initially, volts were low but then took a while to get up to normal. After alternator install, volts were low all the time. There was no improvement but there was major change in that the charge voltage is not making it to the battery.
1981 911SC Targa |
Just curious, why has no one mentioned the Voltage Regulator?
Tom |
OP mentioned VR in first post. Was basis for changing to another alternator.
1981 911SC Targa |
porsher
'kin hell!!!
So I opened up the back of the alt to check my wiring, wouldn't have been the first time I screwed something up. Nope everything is in the right place. I even cleaned up the ground ring lug for good measure. Still no charge. Then I pulled the (almost new) battery out of the tundra and hooked it up with jumper cables. Porsche battery out of the circuit. engine off 12.66V engine on 12.33V let it warm up for a couple of minutes, revved the engine a bit - no change! Bastard!
porsher
I just connected the engine block to the battery ground with a jumper cable.
No change/No charge.
What is the 12 volt level in the engine compartment....?
Engine off, key off. Engine off, key on. Engine running, idle 2000 RPM? |
Not sure which pin.
1981 911SC Targa |
One of the 3 fuses in the engine compartment has unswitched power.
Or maybe all three.... |
porsher
So I *may* have fixed it.
I took a wire and connected the blue wire, from the engine side of the 14 pin connector, to the blue/red side of the battery indicator on the dash. It worked: engine fired up and voltage gauge was immediately up around 13.5+ There is little doubt that it was a self-inflicted wound, it's just a matter of which weapon was involved. Some of the wires were a little crispy from a welding project. Then there was the wiring clean up that I did a few weeks ago, and the race I did in the pouring rain 2 weeks ago. Thanks for everyone's help.
