Seeking Photo of Charcoal Cannster (Under Right Rear Fender)
I'm relocating my charcoal canister after the installation of my PMO ITB and I have purchased the later, round style canister and bracket. I'm looking for a good photo of this installed that I can use as a guide. I don't want to drill any holes until I have it all figured out and I want to mount in the factory location that was on the later cars. Mine is a '74 so don't have any factory holes drilled.
Thanks in advance. |
No pic of it installed but you can see here the studs the bracket attaches to
Shirish 1987 Carrera, Granite Green |
Thanks! That's a start and at least lets me know where it's supposed to go.
Here is a picture of it installed. Hope this helps.
Man, that looks heavy...
JR |
Got it installed last night and if fits perfect.
Not as heavy as it looks, btw. 2lbs 3oz. About 4lbs lighter than the original metal canister that came with my '74. My PMO's are lighter than the original CIS as well ![]()
Thanks All, I got it installed. pictures were a big help.
This thing is pretty useless. I would tear it out.
http://www.carrera-32.com |
Uncertifiable!!!
Vern, hope you don't mind hijacking this thread but steenkamp makes a point that that has been repeated many times in this forum. My question is what do you do with the hose end going into the canister- leave it to the air inside the rear wheel well, loose inside the engine compartment, or, attach directly to the air intake?
Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 10-08-2015 at 07:45 PM.. Reason: Signature |
