Runnin on empty
Porsche as a Tire Bead Breaker
101 things you can do with your Porsche.
Bead Breaker:
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff. https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html |
I like the width if that wheel but strongly dislike the condition of the tire's sidewall..
Member 911 Anonymous
Wow. :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
That is wrong !!! Why would you do that?
Runnin on empty
Surprisingly it works very well. Zero damage to the rims! The small footprint of the jack slips under the lip. My centers are at the Powder coaters and I needed to get the lips to the polishers. The tires are over 17 years old.
Looks to me like the tires are re-treads!?
Tom |
Spiderman
Great use of resources, got the job done without drama. Creative thinking is the best.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
looks like the edges were carved up by the fender..
okay you break the bead awesome .. then what ? whip out two spoons and get the tire off ?
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Probably just lift 1/2 of the multi piece rim off. Which would be very hard if the tire bead was still on it.
This is a trick my father showed me in the early fifties. He learned it from my gramps in the thirties. 18" curved and straight Michlein tire irons are handy for popping the tire off. No-Mar makes some irons with plastic faces for our fancy alloy rims.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 Last edited by FPB111; 10-07-2015 at 02:26 PM.. |
Runnin on empty
These are 3 piece BBS. No utensils needed(spoons,forks etc.)
The tire shown is actually a cut away of another tire sitting on top of a whole tire. Really no drama in doing this. Tires were on this car when I picked it up a couple of months ago. Vintage BBS has no inner channel for tire installers to pull off old tire. So the reason for needing to do this. And thanks Jesse
