-   -   Testing a Permatune CDI (http://forums.pelicanparts.com/porsche-911-technical-forum/886508-testing-permatune-cdi.html)
LM3929 10-10-2015 10:33 AM
I want to test a Permatune CDI box, do I have to use their coil as well or is it just a plug and play situation?
Thanks Lorne M.
Bob Kontak 10-10-2015 10:43 AM
If you are just going to put it on the car and see if it works I don't believe any special coil tweaks are necessary.
Bob Kontak 10-10-2015 10:51 AM
Here is Permatune's link on installation. Note in the first couple of paragraphs the ignition coil is mentioned. Main thing is the resistance should be in the correct range and they reference a bench test. I did not look for the bench test in their site but I believe it is there.
Helpful reading.
911SC902, 911SC & TURBO, 1978-1989 « Permatune
LM3929 10-10-2015 11:39 AM
Thanks Bob, I was hoping to just plug it in to the harness and add an extra ground and hope for the best.
Thanks again Lorne M.
patz 10-10-2015 04:12 PM
usual test is to toss in in a lake. If it floats, it MIGHT work.
LM3929 10-10-2015 04:51 PM
Sorry you are mistaken, that test was for heretics or witches
Lorne M.
steve911T 10-10-2015 06:11 PM
Bob is correct, go to the permatune website and find the instructions, very easy to check to see if it is ok. In other words, if I can do it, you can. Steve
