-   -   Problem removing Headlight.. (http://forums.pelicanparts.com/porsche-911-technical-forum/886567-problem-removing-headlight.html)
Joehand1 10-10-2015 05:51 PM
OK, I thought looking at the U tube videos and all that would help me remove my H5 headlights from my 87 911 so I could replace the bulbs and clean the lens....
But...after I removed the painted rim after taking out the phillips head screw on the bottom, the remaining flat head screw that was supposed to be there on the bottom wasn't there.
I went to the other side and again I don't see that described inner screw at the bottom of the light...
The headlight housing still seems well encased..
What didi I do wrong??:confused:
john walker's workshop 10-10-2015 06:01 PM
find the 4 screws around the outside of the lower framework that attach the assembly to the fender. 2,4,8, and 10 o'clock.
Arne2 10-10-2015 06:29 PM
The video you watched was for H4, different from H5. You don't have the flathead screw on yours.
Joehand1 10-10-2015 08:16 PM
Yes thanks! I thought though that 87 Carreras had H5s unless it was added.
