87 911 - not started for 2 years
Hi all
I'm looking for advice on starting up a 911 that hasn't run for a couple of years. It's spent the last 20 years stored away in a warehouse and only used a few times a year, covering only 12,000km in that 20 years. 2 years ago the (now elderly) owner went to start it only to find the battery wasn't quite up to it so although it turned over, the car didn't fire up. He then left it and here we are today with a car that hasn't spun over for 2 years and me (perhaps foolishly) offering to help get it running again So, is there a secret to starting one up without damaging the engine? I'm not familiar (yet) with flat 6's or air cooled engines so I'm concerned about damaging the piston rings after so long and getting some oil round it. Normally I'd do that just by popping the coil lead off, pulling the spark plugs and cranking it with a fresh battery until the oil light goes out but am I likely to cause any harm with that approach ? Is there a better way with a 911? Or am I worrying about nothing and should just be splashing some fresh fuel in and strapping in a new battery? Cheers Mike |
New battery, pull the coil wire and crank it till you see oil pressure then try to start it. 2 years is not horrible, my new to me 79 turbo sat for about 15 years and it's kind of problem child.
Vintage Motorsport
Drain the gas tank and put new gas in.
Do not use ether to start the car. Richard Newton |
Yeah, I'd thought of draining the tank out, it'll be useless in there now. Aussie fuel isn't great when it's new, never mind over 2 years old...
We need pics of the car ..
It's just an old silver Targa....
If it doesn't start due to an apparent lack of fuel it could be due to the injectors. You can tell by introducing a little bit of starter fluid (or break cleaner) into the air filter. If that makes it run for a little bit it'll tell you are missing fuel.
Often times the injectors will be stuck shut when a 3.2 sits for more than a couple of month. While someone cranks use a large screwdriver handle and gently tap them gently to free their pistons. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Like Richard said, drain the tank and use new fuel. Pulling the plugs and squirting some oil in the cylinders, then turning the engine over a few times (but not starting) wouldn't be a bad idea. After it's running, don't be too surprised if the fuel pump dies shortly after (seen that one a few times in that circumstance). Also, inspect the fuel lines and replace the high pressure ones. I hate to see cars like that go up in flames.
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
Ingo & Pablo, thank you
Is there a drain plug on the bottom of that tank?
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Well, gave it a try today but no joy, think the fuel pump has given up. Removed all the plugs, sprayed some oil in, spun it over and it very quickly showed oil pressure on the gauge so all good there. Plugs back in, but it made absolutely no attempt to fire up. Checked the pump and it's silent, would've expected at least a humming noise from it? Gave the relay under the seat a tap but that didn't do anything either. Not long after that, I noticed all the ignition lights were on, which was somewhat odd considering I had the keys in my pocket...
Seems it's developed some kind of electrical problem while I was trying to get it going, couldn't work out what the fault was so removed the battery and left it. The owner's going to get an auto electrician to look at it, they can probably diagnose the fuel pump at the same time. Shame, was looking forward to hearing it fire up !! |
Straight shooter
Check for rodents.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
No evidence of rodents anywhere in the car, it was a concern of mine anyway.
keep in mind that the fuel pump will only start running with the engine turning over. Don't expect to hear it pumping when you turn ignition on.
nah,spiders and snakes in that part of the world....true
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Yeah, they've already eaten the rodents
![]() Didn't realise I wouldn't hear the fuel pump unless the engine was cranking over, was expecting to hear it humming with the ignition on. Having said that, I couldn't hear anything when it was cranking either so it's still prime suspect along with the relay. Does the relay plug just pull off or does it have some kind of locking tab? After unbolting it from the floor I couldn't get it apart, eventually the relay cap came off rather than the plug coming off, caused no end of sparks until I disconnected the battery. Looks a little better without some of the dust
I'm not a carrera expert (though I'm a sort-of SC expert now if you read my ongoing topic :-)). I'd first test to see if you have spark. Next check for fuel. You can put 12v to the fuel pump to see if it runs. I'm sure there is an easier way. On the SC you can jumper the fuel pump relay to do the same test much easier. Check for fuel and gas before you chase random electrical gremlins. It doesn't hurt to check/clean the contacts on the relevant fuses and relays. Good luck!
That car looks pretty clean. Is that just dirt on the hood? Not rust? |
If you do a search you will see that electronic injectors can stick closed while sitting over a long period. Not sure but it's something to check.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Yeah Anthony, it's just dust on the car, it's been sat in the very dusty warehouse untouched. Prior to coming to Melbourne 20 years ago it was 'country' car, so has seen a fair number of dirt roads in its life. Certainly plenty of evidence of that when I was working in the engine bay yesterday, parts of it are stained orange from the dust that's accumulated in there but underneath is in very good condition, no rust or damage (which is a surprise). The hood needs repainting as the paint's cracked towards the leading edge as the current owner had it badly painted when he bought it just to cover some stone chips. The rest of the paint is *very* clean, a good polish and it'll come up well.
I'd read about sticky injectors, will have a crack at them next time I go in there, but first the owner needs to get his auto sparky in to look at the ignition problem. No point starting it if it can't then be turned off ! |
