Is this needed or can I delete?
I need some help to understand this: There appears to be a cable tie (or a tab) located on the replacement floor board in what will be the space in-between the outer and inner panels (front driver's side, near the pedal area). My question is whether it is used for something (what??) or if I can cut it off since it will never again be accessible once the floor is in.
Any help appreciated! Dario http://forums.pelicanparts.com/uploa...1444718986.jpg http://forums.pelicanparts.com/uploa...1444719027.jpg |
It's a tab to hold a wire harness in place on the inside of the car.
Wire harness? I need to pass wires before welding up the floor? Can you tell me which wires, my car came without a floor! I'm in dire need of community knowledge to avoid dumb mistakes...
Help! |
| All times are GMT -8. The time now is 03:10 PM. |
