mark13 (guest)
Guest
Posts: n/a
Thanks Nick for your help. Turned out to be a loose casing throughbolt, so I replaced the 'O'ring and re-torqued. It would have stopped leaking once the casing expanded when hot. I replaced the seals with an extra set that I got from you at the same time. I checked my thermostat at the same time and it wouldn't even open at 290 degF so will replace that too. Thanks again. mark13
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-14-2015, 07:01 AM
Nick at Pelican Parts's Avatar
Thanks for the follow up. We appreciate it.
- Nick
