VDO clock issue ( after rebuild )
Hey everyone -
So I just got my clock back from a rebuild service and noticed that there is a lot of play in the center adjusting arm. ( left and right wiggle, up and down wiggle ) There is also a lot of play in the white clock arm and some in the glass if i wiggle the center adjusting arm. I don't remember any of this being there before i sent it off for a rebuild. ![]() Anyone else have this with their clock ? The clock does seem to be keeping accurate time. Here is a video : https://youtu.be/3Va3qVSzxAA thanks Kevin
1974 911 w/Sportomatic 2006 Carrera 4 2010 Cayenne ( SOLD ) 2015 Macan S Last edited by TRACKS; 03-12-2018 at 06:10 PM.. Reason: changing title to be more accurate |
The video is not working...for me, anyways.
This guy could fix it....https://www.facebook.com/specialtygauge/ Last edited by stevej37; 03-13-2018 at 05:23 AM.. |
sorry - video should work now
1974 911 w/Sportomatic 2006 Carrera 4 2010 Cayenne ( SOLD ) 2015 Macan S |
I don't know...doesn't look right to me.
My 84 has a black plastic or rubber bushing that is in the gauge face. It keeps the stem rigid. Is yours missing? |
i have that -
I looked at it again..... its like the glass is not mounted tight , so the center adjuster and the glass are wiggling around together... ugh The clock is still keeping time after about 16 hours though ..
I would pull the clock out. Look to see if something is wrong with the band that is around it.
Good luck..you'll get it fixed. |
Titanium User
Maybe the trim ring isn't properly seated.
dg567 / Steve -
thanks, Yep - I think something didn't seat correctly when the trim ring got reinstalled. ![]() The only thing to do now is send it back and have them redo it. Its clearly not right. Kevin
Titanium User
Can you press the trim ring down any further?
