4 jack stands necessary
A few questions to DIYers. I need to do the motor mounts, tranny mounts and tranny fluid for my 911. Is it better to have it up on 4 jack stands or 2?
I'd like the car to be level, but I also worry about safety. I'll have a floor jack under the car but I will be using it to hold up my motor or tranny most of the time. Level of difficulty for this project? Thanks! |
don't need the car to be level for the mounts but for the gear oil, nice to have it level. all easy work. just don't spill that stinking gear oil.
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
I'd use a set of ramps and blocks to get the car level for the gear fluid.
None of these are hard tasks, but be sure to see if you can loosen the fill plug before you drain the tranny. I'd say level 1 difficulty. Sent from my iPhone using Tapatalk
‘84 Carrera, heavily modded Please follow me @chopped_up_fitness |
Burnin' Rubber
The higher the better. You prolly will need room for leverage because lotsa people love to overtighten the transmission drain and fill plugs
Member 911 Anonymous
OP,
What year is your car, if an 87-89 ( G50 ), the trans mounts is the whole assembly. If a 915, assuming the car is warm, just raise the rear end, place on jack stands at TB caps, leaving the jack in place, loosen the cross member bracket bolts (2 each side) then remove the ttrans mount bolts (2), lower the gear box a bit and remove the mounts and replace with new ones. Insure the bolts are straight, the trans mount bolts are very easy to cross thread. As for the gear lube, take this time to insure the fill plug can come off, if not stop. You need to insure the fill cap can be removed. DO NOT DRAIN THE LUBE until fill plug can be removed. If good, proceed to draining the lube. While draining, lower the car and bounce on the bumper to remove the pre-load. We want her level ( a warmed gear box is best time to drain, as noted above ) Assuming you bought a cheapo pump at the FLAPS, replace drain plug, torque to spec, route the fill hose tip into the fill plug and start pumping away. It will take about 3.25 quarts of lube or stop when you see fluid coming out of the fill plug, let it continue to drip until it is barely dripping. That's it. ![]() Alternatively, you can raise the driver side, open the fill plug then the drain plug, lower then fill up as above.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 10-15-2015 at 12:23 AM.. |
Thanks! |
To get your feet wet on this project, just put a jack under the engine to hold its weight, and replace the rear engine mounts while the car is still on the ground. Piece of cake that part
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
when I refill, I fill till full & then wait 1/2 hour to check if it will accept more. sometimes the oil takes a while to make its way to the bottom over the gears etc
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
abides.
Don't forget to brace the engine crossbar when you remove the engine mount bolts. If the mounts are old and the bolts are tight, the ends of the bar can bend or even tear off.
Graham 1984 Carrera Targa |
I vote 4 jackstands.
The higher the car, the easier the job (tranny mount and gear oil) Gear oil fill plug may need a cheater pipe. You may need clearance from the ground. Tranny mounts are annoying to work at when right next to your face. I did not loosen any tranny cross beam. I just removed that fuel pump cover plate (PITA to reinstall, worst part of the job) and just replaced each mount one at a time. Need encouragement (and help) to attempt gearbox motor mounts replacement. Fill plug on 915 gearbox has blocked clearance
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 10-15-2015 at 02:11 PM.. |
For the engine mounts, if the bolts don't start releasing with moderate pressure, get some rust penetrator, spray, and try again 2 hours later. Bending or breaking your mount is quite possible if you apply a lot of pressure, and quite expensive.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Once you get under there you will see what I mean.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Any tips on avoiding bending the engine crossbar. I've seen a dozen warnings about how the welding is weak but no advice on how to do it.
I don't have an impact wrench and it looks like my mounts are original 1986. Am I good with some socket and box wrenches? WD40? I also can't find any good comprehensive DIY threads. Any pointers are welcome! Thanks |
4 is the best for safety.
