First Check for inoperative lock
Today, I am unable to turn the driver's side manual door lock. If I hit the central lock button in the console, the passenger lock closes and the driver's lock moves slightly, then the passenger lock pops back up.
I can put the key in the door handle and turn it easily, but central locking doesn't even try to engage.
I don't see any blown fuses at all.
Before I start removing stuff from inside the door (as indicated in the Bentley manual), are there any typical steps to check first?
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 10-20-2015, 08:10 AM
T77911S's Avatar
i would pull the door panel and take a look. there are some rods in there, may be plastic, that can come off/break.
i had to "wire" one back on on my 930. i have the part for next time it fails.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-20-2015, 09:19 AM
Member 911 Anonymous
DRACO A5OG's Avatar
While you are there, I would also look for a white wire, it may have severed and causing a short.
Over time, if it dislodges and sit on a moving part, it will rub off the lining and then short it out. When it grounds out, it will default open.
'85 Carrera Targa
PCA/POC
Old 10-20-2015, 09:25 AM
It's obviously some mechanical obstruction. I slammed the door one good time and it lock and unlocks easily. I'll have to take a look and see what is hanging it up so that I don't end up having to crawl in or out of the passenger side if it sticks in the locked position.
Old 10-20-2015, 11:30 AM
Undocumented User
McLaren-TAG's Avatar
Bangin' it hard was the first step listed in the Bentley manual?
Old 10-20-2015, 11:47 AM
